1
How to export with new page numers
Apr 18, 2017 Apr 18, 2017
I need to export a selection of my file and want this export to have new digital page numers. E.g. my document contains 100 pages, I want to export page 80-82 and want these pages to have new digital page numers 1-3.
My document does not conain any page numer boxes, so the page numer is not displayed on the page. When I make an export, the digital page number still shows 80-82 (when viewing it with for example Adobe Acrobat), although it also shows page (1 of 3), see picture.
So to be clear, I want the box where 80 is displayed to show page number 1  and when looking at the second page page number 2 etc.
Does anyone know how to accomplish this?
2.2K
Community Expert , Apr 18, 2017 Apr 18, 2017
So you need the numbers to remain 80-82 in the InDesign doc, but renumber 1-3 in the PDF?
Open the 3-page PDF in Adobe Acrobat DC
View > Show/Hide > Navigation Panes > Thumbnails
Right click page 80 > Page Labels
Choose begin new section, Style 1,2,3, Start at 1.
If you don't have Acrobat (only Reader) you might save the InDesign document as a new file. Delete the pages before and after pages 80-82, and allow InDesign to renumber the pages in the Pages panel. Then export the 3 pages.
Are you doing this in InDesign? If so, what version? The screen capture you provided is in either Adobe Acrobat or Adobe Reader.
The screen shot is made from Adobe Acrobat, where I want it to display the new digital page numbering.
The document is made in InDesign CC.
These are my export settings:
So unless you want to make a new 3-page pdf out of your file, open Acrobat and renumber there, as per my instructions above.
Adobe Employee ,
Adding to Barbara, PDF preserves the same numbering scheme as it was created  from Indesign.
Creating sections to show desired page numbering in PDF(not a good solution) is one of the workaround that you can use. Otherwise, following what Barbara showed is a good solution
-Aman
BarbBinder​
Thank you for your solution, this works for me. Too bad this isn't a (simple) option in InDesign.
I'm glad it worked!
As Aman said above, Acrobat uses InDesign's numbering, which is normally exactly what we want. When I save a book to PDF that has front matter in lower case roman numerals (i.e., i, ii, iii) and the body in arabic numerals (1, 2, 3), they translate perfectly to Acrobat. The reason I know how to renumber in Acrobat is because not all programs can do this. I've spent years having to manually update the numbers in Acrobat to match the running heads. Your situation is very specialized—but luckily there is an answer for you as well.
