I deinstalled everything and installed it and nothing works.
I pay for this 35 € per month. this is so weird.
I just used Tracker an than this error appeared.
Analysis error of memory .. smth .. cant translate 😮
HELP!!!!!
I just had the exact same problem. Deleting the following directories/files did the trick:
/Library/Application Support/Adobe/SLCache
/Library/Application Support/Adobe/SLStore (you will have to re-enter your Creative Cloud account credentials afterwards)
/Users/[USERNAME]/Library/Preferences/com.Adobe.After Effects[.x.y.z].plist (I deleted all files)
/Users/[USERNAME]/Library/Preferences/Adobe/After Effect (whole folder, including all subfolders)
Good luck!
Tim
when do you see that error? what program? what os?
after effects 2017. it appears when I use the tracker
[moved from Adobe Creative Cloud to After Effects]
Kann keiner wissen. Keine Systeminfo, keien genaue Versionsangabe, keine Details zum Projekt.
Mylenium
Bei mir das Gleiche. Auch nach Neustart taucht diese Fehlermeldung auf, sobald ich versuche das Text- oder Absatzfenster zu öffnen. Text somit absolut nicht editierbar.
Bei einem Grafik-Programm: worst case-Szenario.
Hi ThomasW,
Are you still having trouble with After Effects and tracking? Let us know.
Kevin
I currently have the same problem!
Message appears when I try to open the tracker window.
"After Effects Warnung: Fehler bei der Analyse der Eigenschatenliste aus dem Speicher."
Afx v 14.2.0.198
First of all, I would recommend updating. The recent bug fix update solved some memory problems.
I tried to solve it with the update. -> Fail
Problem is still present
What tracker are you trying to use?
I try to open the tracker overview window from the window tab. All trackers are working fine. In order to have access to it, I always have to change the workspace to a default.
Good luck!
Tim
Thank you!! Unfortunately, I use Windows 😕
That's no obstacle!
Under Windows the folders should be in
ProgramData\Adobe\
and [USERNAME]\ProgramData\Adobe\ (I guess)
Tim
In my opinion, windows itself is an obstacle
I think I got it -> C:\Users\MEuser\AppData\Roaming\Adobe\After Effects -> rename the latest folder (in my case 14.2)
thanks for your advice
Hello everyone,
we pay a lot of money for the software and now with version Adobe After Effects 2018 we have the same error:
doesn't matter what we do, try typing, try to scale something, try to animate some stuff, everytime we get this error.
AND NO ONE and NOTHING HELPS. Reinstalling don't, clear all Preferences and Logfiles don't and complete deinstallation, restart of the system and new installation doesn't help. And not only with existing files, also with new files and creations, everytime this error. And what does ADOBE??? NOTHING. Thats not the way its used to be my friends.
Kind regards
If the suggestions of the other people in this thread do not work for you, please contact Adobe support.
I have a similar problem with Premiere Pro 2020 (Version 14.0.3) on macOS Catalina. It won't go any further than the Get started-interface, neither uninstalling nor changing the work areas (as suggested below) worked out the problem. I can't find the given directories/files which were recommended to delete in this post though...
Very thankful for any advise!
Hey,
I found (through long hours of research) an easier solution:
If this error pops up just change your work areas / layout (Arbeitsbereich) to "standard". You can do that under "Windows - Arbeitsbereiche".
This way, I hope it works for you too, you don't need to delete or re-install anything.
