I have a menu bar which need to use the function multiple times, how can i make the function reusable in every scene/frame?
Scripts that are in frame 1 should be usable in any other frame. Do you have an example FLA that you can put online somewhere, that shows the problem you're having?
But I have different scene which need to use the same function as well.
The script in frame 1 of scene 1 should still work in scene 2. I tried this script in scene 1:
test();
function test(){
trace("test1");
and this in scene 2:
test();
stop();
It traced "test1" twice. So, scene 2 was able to use scene 1's function.
Okay, thanks. Can i know how to pause audio and play back from last position without declare
var mySound:Sound = new Sound();
I want to stop the frame and play it when click on "play" button.
Any sounds that you cut off with a blank keyframe in scene 1 will not be heard in scene 2.
Also, these lines of script will stop everything:
import flash.media.SoundMixer;
SoundMixer.stopAll();
SoundMixer.stopAll(); will stop all the sound but how can i pause it and play it from the last position? i tried as below
var myChannel:SoundChannel = new SoundChannel();
var myTransform = new SoundTransform();
var lastPosition:Number = 0;
myChannel = mySound.play();
myTransform.volume = 0.5;
myChannel.soundTransform = myTransform;
pause_btn.addEventListener(MouseEvent.CLICK, onClickPause);
function onClickPause(e:MouseEvent):void{
lastPosition = myChannel.position;
myChannel.stop();
play_btn.addEventListener(MouseEvent.CLICK, onClickPlay);
function onClickPlay(e:MouseEvent):void{
myChannel = mySound.play(lastPosition);
