Need help how to access coldfusion 11 from outside via port forwading.
Guest
Apr 18, 2017 Apr 18, 2017
hi all!
i want to access my http://localhost:8080/cfusion_dev/CFIDE/administrator/index.cfm from outside.
i already configure my router to port forwading 8080 but still i cant access?
i have windows server 2012 r2 operating system..
guys can you give me a instruction how to fix this..
thank you!
regards,
boygie
666
Guest
guys i this one also.
i check my port on http://www.yougetsignal.com/ i got result port was closed.
but if trace 8080 port on asa wife wall i got allow result.
Advocate ,
Apr 19, 2017 Apr 19, 2017
This could be a range of issues, all depending on your hardware. Its not really an issue related to Coldfusion. I would recommend asking on a forum that gives help for port forwarding / server management.
The other obvious thing I can add is that I assume you have checked the (windows) firewall on the server itself. Is it active and if so, does it also allow port 8080
Participant ,
In IIS, go to your website -> bindings and make sure you have 8080 listed as a port. IIS is the one doing the listening, not CF.
Guest
Apr 21, 2017 Apr 21, 2017
You may want to check the firewall on the server as you can set rules in here for local / domain traffic and external traffic.
Have a look at the MS guides Add or Edit Firewall Rule (for Remote access) or https://www.vultr.com/docs/how-to-open-a-port-in-windows-firewall-on-windows-server-2012 (for 'PUBLIC' access).
Andrew
Documentation
