Ok figured it out. I recently installed a Wacom Tablet Driver and when im not using it it dissallowed me to move things in photoshop but i just had to uninstall it.
Also the layer is not locked if that was what you were thinking
Works fine on my windows machine.
Have you tried resetting your preferences?
How would i do that?
This should help you.
http://www.photoshopessentials.com/basics/photoshop-troubleshooting-resetting-preferences/
Jim
I reset them and it still does not work. I also uninstalled it and reinstalled it and it still did not work
Can you post a screen shot of your layers panel?
Turn Auto-select ON
That still does not allow me to move layers
What I don't get is that his task bar should like like this and it doesn't
I don't know if this helps but when i try to drag my cursor goes white much like the direct selection tool
Also there is no photoshop icon
Tiny screen shots like that are not helpful. We need to see the context to understand what is going on. Just grab the entire screen, and paste to this thread with Ctrl v (Cmd v). You don't need to use the third part image hosting site.
Also if i select part of a layer i can move the selected part around
Can we clarify exactly what your issue is? Are you saying that you are unable to drag an object around the canvas with the Move tool? And you have Auto select turned off in the Options bar?
The white cursor arrow is correct, and changes to white from the Move tool cursor as you start dragging the layer content. With Auto Select unchecked, you can enable it by Ctrl clicking the layer content, (which is my preferred way of working).
This is so unusual, I strongly suspect something else is going on, like you have a Copy-merged layer at the top of the stack which is hiding the movement. If you open Layer Panel Options and chose the large thumb nail, does the object move in the thumbnail, or is it definitely static?
If you still have the issue, a screen shot of your entire workspace might help. Un dock the layers panel and expand it so we can see as many layers as possible, and perhaps twirl shut the layer effects. There is something a bit weird going on here methinks.
Here if a video of it not working
Thanks for the video. I have watched it several times and can see nothing wrong with your workflow. We can see the cursor change to the white arrow indicating that you have the mouse button pressed. The layer is not locked. AFAICT it should work, but it doesn't.
It looks like Windows 10. What have you tried? I believe you have reset Preferences?
Have you reinstalled Photoshop?
Have you restarted your computer and Photoshop?
Have you tried a new image document?
Are you using a mouse, or tablet, and have you tried a different mouse?
First thing to try is starting Photoshop with the Shift key depressed to force it to ignore any third party plug-ins and extensions. If that gets it working, then you'll obviously have to uninstall them one at a time to see which one is the problem. If that makes no difference, reinstall Photoshop but run the Cleaner tool.
Use the Creative Cloud Cleaner Tool to solve installation problems
Fingers crossed that fixes it, because I am struggling to think what else might be causing this.
Good luck
Is there a way to downgrade PS to see if it really is 2017 or nor
The thing is, those of us that have responded and are using Windows 10 with CC 2017, are not having this issue. So it seems to me that there is either something happening with your operating system, like a broken API, or that Photoshop is broken. If you have not already done so, it really doesn't take long to reinstall, but be sure to run the cleaner tool (linked in post #17).
I assume you have tried starting Photoshop with the Shift key depressed to rule out third party plug-ins and extensions?
If he decides to go that route he should also use the ACC cleaner tool, reboot and then re-install PS.
he might also run a registry cleaner for added effectiveness.
Jim
jbmoo7,
I think the difference is in your screenshot that's how the Move Tool options look when one has Enable Narrow Options Bar checked in Edit>Preferences>Workspace, which uses some icons in the place of text
The ops is apparently not checked.
I have done all of these and it still does not work and the condensed bar did not do anything just made it look different
