Hi, I'm very new to Animate - so be gentle with me please!!
I have all of the illustrations prepared in Illustrator which I'm importing through CC library into Animate.
I'm trying to get something to animate with movement and a change of transparency if possible. Imagine a bull running with steam coming out of it's nose, so appearing quickly from 0% opacity to about 75% opacity and back again.
Is this possible in Animate?
Many thanks.
Yes, off course,
First start to change your graphic into e symbol. If you don't plan to add any interactivity - use Graphic Symbol in this case.
Then
Select your symbol in timeline window and use right mouse buton to turn it into a Tween. Select Create Motion Tween options.
Go to last frame (your tween probably is 24 frames long - your Frame Rate settings) - maybe 24 select symbol on Stage and chage it's opacity in Properties Panel to 75%. Finally go to first frame and change Opaity to 0%
You can adj
...Copy link to clipboard
Yes, off course,
Then
You can adjust length of your animation (speed) by dragging last frame of your Tween in timeline
Pawel
Marvellous, and thanks very much fro the info - That's the sort of thing I would have expected, but I wasn't converting it to a symbol.
Many thanks and have a good day.
Trev
