Photoshop is not opening ANY files...JPGS, PNG,PDF,PSD...you name it.
Photoshop CC (2017) opens, I see the top tool bar, but all the pulls down options are greyed out as if I haven't opened a file, the and then nothing happens. No tool pallets, and just a black background. I'm on Windows 10. How do I fix this? Photoshop is totally useless at this point...I've downloaded and I'm using GIMP which is very nice and free. Adobe In Design and Adobe Pro DC work fine.
[Moved from non-technical Lounge Forum to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Try resetting Photoshop Preferences.
Start Photoshop and immediately id not sooner press and hold Ctrl+Alt+Shift (Windows) CMD+Option+Shift (Mac) If done on time Photoshop Should open a Pop_Up Dialog windows. Do you want to delete your Photoshop Preferences. When you get that Dialog Window reply YES......
I was able to delete the Photoshop Preferences but this did not work, and photoshop is still not opening files.
Use Photoshop menu Help>System Info. Copy and Past that information here.
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877 x64
Number of Launches: 2
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3408 MHz
Built-in memory: 32634 MB
Free memory: 20230 MB
Memory available to Photoshop: 29404 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1440, right=2560
Display: 2
Display Bounds: top=129, left=-1920, bottom=1209, right=0
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
License Type: Subscription
Serial number: ########
GUIDBucket:
bucket: 233
test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\JSZILA~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 468.2G, 359.9G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.0
Plugin.dll Adobe Photoshop CC 2017 18.1.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.0
PSViews.dll Adobe Photoshop CC 2017 18.1.0
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Accented Edges 18.1.0 - from the file “Filter Gallery”
Adaptive Wide Angle 18.1.0 - from the file “Adaptive Wide Angle”
Angled Strokes 18.1.0 - from the file “Filter Gallery”
Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Average”
Bas Relief 18.1.0 - from the file “Filter Gallery”
BMP 18.1.0 - from the file “Standard MultiPlugin”
Camera Raw 9.1.1 - from the file “Camera Raw”
Camera Raw Filter 9.1.1 - from the file “Camera Raw”
Chalk && Charcoal 18.1.0 - from the file “Filter Gallery”
Chrome 18.1.0 - from the file “Filter Gallery”
Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Cineon”
Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Color Halftone 18.1.0 - from the file “Standard MultiPlugin”
Colored Pencil 18.1.0 - from the file “Filter Gallery”
CompuServe GIF 18.1.0 - from the file “Standard MultiPlugin”
Conté Crayon 18.1.0 - from the file “Filter Gallery”
Craquelure 18.1.0 - from the file “Filter Gallery”
Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.1.0 - from the file “Standard MultiPlugin”
Crosshatch 18.1.0 - from the file “Filter Gallery”
Crystallize 18.1.0 - from the file “Standard MultiPlugin”
Cutout 18.1.0 - from the file “Filter Gallery”
Dark Strokes 18.1.0 - from the file “Filter Gallery”
De-Interlace 18.1.0 - from the file “Standard MultiPlugin”
Dicom 18.1.0 - from the file “Dicom”
Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
Diffuse Glow 18.1.0 - from the file “Filter Gallery”
Displace 18.1.0 - from the file “Standard MultiPlugin”
Dry Brush 18.1.0 - from the file “Filter Gallery”
Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “EazelAcquire”
Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
Extrude 18.1.0 - from the file “Standard MultiPlugin”
FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “FastCore”
Fibers 18.1.0 - from the file “Standard MultiPlugin”
Film Grain 18.1.0 - from the file “Filter Gallery”
Filter Gallery 18.1.0 - from the file “Filter Gallery”
Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Fresco 18.1.0 - from the file “Filter Gallery”
Glass 18.1.0 - from the file “Filter Gallery”
Glowing Edges 18.1.0 - from the file “Filter Gallery”
Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Graphic Pen 18.1.0 - from the file “Filter Gallery”
Halftone Pattern 18.1.0 - from the file “Filter Gallery”
HDRMergeUI 18.1.0 - from the file “HDRMergeUI”
HSB/HSL 18.1.0 - from the file “Standard MultiPlugin”
IFF Format 18.1.0 - from the file “Standard MultiPlugin”
IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Ink Outlines 18.1.0 - from the file “Filter Gallery”
JPEG 2000 18.1.0 - from the file “JPEG2000”
Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Lens Blur 18.1.0 - from the file “Lens Blur”
Lens Correction 18.1.0 - from the file “Lens Correction”
Lens Flare 18.1.0 - from the file “Standard MultiPlugin”
Liquify 18.1.0 - from the file “Liquify”
Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MeasurementCore.8me”
Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Mezzotint 18.1.0 - from the file “Standard MultiPlugin”
Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MMXCore”
Mosaic Tiles 18.1.0 - from the file “Filter Gallery”
Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MultiProcessor Support”
Neon Glow 18.1.0 - from the file “Filter Gallery”
Note Paper 18.1.0 - from the file “Filter Gallery”
NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “NTSC Colors”
Ocean Ripple 18.1.0 - from the file “Filter Gallery”
OpenEXR 18.1.0 - from the file “Standard MultiPlugin”
Paint Daubs 18.1.0 - from the file “Filter Gallery”
Palette Knife 18.1.0 - from the file “Filter Gallery”
Patchwork 18.1.0 - from the file “Filter Gallery”
Paths to Illustrator 18.1.0 - from the file “Standard MultiPlugin”
PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PCX”
Photocopy 18.1.0 - from the file “Filter Gallery”
Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
Pinch 18.1.0 - from the file “Standard MultiPlugin”
Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Pixar”
Plaster 18.1.0 - from the file “Filter Gallery”
Plastic Wrap 18.1.0 - from the file “Filter Gallery”
PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
PNG 18.1.0 - from the file “Standard MultiPlugin”
Pointillize 18.1.0 - from the file “Standard MultiPlugin”
Polar Coordinates 18.1.0 - from the file “Standard MultiPlugin”
Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PBM”
Poster Edges 18.1.0 - from the file “Filter Gallery”
PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Radial Blur 18.1.0 - from the file “Standard MultiPlugin”
Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Radiance”
Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
Reticulation 18.1.0 - from the file “Filter Gallery”
Ripple 18.1.0 - from the file “Standard MultiPlugin”
Rough Pastels 18.1.0 - from the file “Filter Gallery”
Save for Web 18.1.0 - from the file “Save for Web”
ScriptingSupport 18.1.0 - from the file “ScriptingSupport”
Shake Reduction 18.1.0 - from the file “Shake Reduction”
Shear 18.1.0 - from the file “Standard MultiPlugin”
Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Smart Blur 18.1.0 - from the file “Standard MultiPlugin”
Smudge Stick 18.1.0 - from the file “Filter Gallery”
Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Solarize”
Spaces 18.1.0 - from the file “Spaces”
Spatter 18.1.0 - from the file “Filter Gallery”
Spherize 18.1.0 - from the file “Standard MultiPlugin”
Sponge 18.1.0 - from the file “Filter Gallery”
Sprayed Strokes 18.1.0 - from the file “Filter Gallery”
Stained Glass 18.1.0 - from the file “Filter Gallery”
Stamp 18.1.0 - from the file “Filter Gallery”
Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Sumi-e 18.1.0 - from the file “Filter Gallery”
Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Targa 18.1.0 - from the file “Standard MultiPlugin”
Texturizer 18.1.0 - from the file “Filter Gallery”
Tiles 18.1.0 - from the file “Standard MultiPlugin”
Torn Edges 18.1.0 - from the file “Filter Gallery”
Twirl 18.1.0 - from the file “Standard MultiPlugin”
U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Underpainting 18.1.0 - from the file “Filter Gallery”
Vanishing Point 18.1.0 - from the file “VanishingPoint”
Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
Water Paper 18.1.0 - from the file “Filter Gallery”
Watercolor 18.1.0 - from the file “Filter Gallery”
Wave 18.1.0 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WIASupport”
Wind 18.1.0 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WBMP”
ZigZag 18.1.0 - from the file “Standard MultiPlugin”
Optional and third party plug-ins:
3DxPhotoshop 2.8.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\3Dconnexion\3DxPhotoshop_CC2017.8li”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions: NONE
Installed TWAIN devices: NONE
I a bit confused about your system info. You many has an installation problem/ You may want to try uninstalling. The use Adobe Cleaner and the install Photoshop. Looking at your Photoshop system info it look like you on Windows 10 however I see
Touch Bar: Enabled.
I also see you had two Displays and you GPU is disabled?
Display: 1
Display: 2
I do not see any information about you display adapter????
I also see you have some third party plug-in installed. Try without the plugin installed.
IMO there should be some information about your Display Adapter on my windows 10 system I have a Nvidia Quadro 4000 Here is whay I see in mys CC 2017.1 system info about touchbar and display
Touch Bar: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1028K
Image cache levels: 6
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-1360, bottom=768, right=0
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: False.
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA Quadro 4000"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7711"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
glgpu[0].GLRendererID=1757
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_78b6fa1429829a91\nvwgf2um"
glgpu[0].GLDriverDate="20170317000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.1 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="Quadro 4000"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="377.11"
clgpu[0].CLBandwidth=7.48e+10
clgpu[0].CLCompute=191.694
I do not have a Nvidia card I have a AMD Fire Pro W4100. The reason there is no GPU on one of the screens is it plugged in to an alternate port on the back of my computer (the one that has a picture to tell you to plug your monitor in). The other screen is plugged into the video card HDMI port because I had issues with the screen turning on and off randomly...I have switch the port on my secondary screen and it now has GPU on the alternate screen.....and guess what. Photoshop now works. The alternate monitor port on the back of the computer is an HDMI port directly off of the video card. Apparently Photoshop was having a sh** fit over the Intel HD Graphics 530 handling the monitor. Go figure that nothing ever works or plays nice out of the box.
Thank you very much for your assistance.
Adobe published the Photoshop can have problems when machine have two different GPU installed. Good to here you got it working.
