Hi everybody!
I need help...
what I want to do is this:
an image gallery identical to the one you use in a smartphone or a tablet...I want it to work also on desktop version...
I did this with muse's widgets. What I'm not able to do is to make the thumbnails move horizontaly...and it's quite a problem...
I'm not able to match the "scroll effect" (with a simple rectangle I made it work) with the thumbnails part of the slideshow.
Any ideas?
P.S.:
I've taken a look at muse themes - Fullscreen Thumbnail Gallery but they say:"This widget works best on "desktop" sites, and is not ideal for use on mobile",
so that is not what I'm looking for...
Laura
I'd really like to recommend this MuseThemes widget https://www.muse-themes.com/products/gallery-connect
It does, what you want, and tons of things more!
Very fine: The gallery is set up completely using a spreadsheet. So the appearace of the slideshow and the images itselves can be changed or modified without even starting Muse.
It is worth, to have a very close look at this widget!
Thank you very much for your quick answer. I'll immediately go to have a look!
