Is there a way to remove watermarks that I have created?
Yes but not in LR. you do that in the File Manager for the OS. The watermark files are stored here.
C:\Users\YourUserName\AppData\Roaming\Adobe\Lightroom\Watermarks
Just delete the ones you no longer want to show up. You can view them with a Text Editor.
Remove watermarks from what?
From the pull down menu where the lists of watermarks are listed. Sorry for not being more clear.
This is correct for a PC but for a mac you need to go to system library re: in finder option click the go button to see system library. Click on library than application support/Adobe/Lightroom/Watermarks
I am not sure how you can view them except in lightroom watermarks panel. As text editor does not show them in MAC. It just shows the code.
In the Export dialog, expand the pull down menu and select the watermark you want to delete...
Then click on Edit Watermarks and expand the pull down menu on the upper left:
Then click on Delete preset....
You will have to repeat this procedure for each watermark you want to delete.
