cannot synch certain images to LR Mobile
Enthusiast ,
Apr 20, 2017 Apr 20, 2017
I have 4 images, a jpg and a tiff of each of two files.
When I try to sync them to LR Mobile, the desktop LR top bar shows "synching 2 files".
This message never clears but the images can be seen in the LR MOBILE display.
If I remove the images from THE MOBILE SITE, the "synching 2 files" is removed.
This only happens with these 2 files.
Ideas?
thanks,
vince
432
Enthusiast ,
A couple things to try. Go as if to edit them in LR Mobile, make no changes, save. See if that clears it. Other possibility, remove from LR Mobile -and- Lightroom. Restart.  These are both based merely on hunches; I think the first worked for me. If either works, pls report back.
Enthusiast ,
Apr 22, 2017 Apr 22, 2017
Thanks so much for your reply. I tried yi=our suggestion with no luck.
I think there must be some fundamental misunderstanding in my mind about how this works.
I must review the literature/instructions regarding this. Perhaps you can recommend a good place to start.
Again, thanks much.
vince
Enthusiast ,
Apr 26, 2017 Apr 26, 2017
Vinsolo, I just cleared an "infinite sync" by removing the image from -all- synced collections. When I returned it, the problem disappeared. Have you tried that?
Enthusiast ,
Thanks. I have done the same with the same results. However, I cannot sync these two images but have no trouble synching any other images. Don't know why as the images respond normally
to all tests I can run.
vince
Enthusiast ,
Last thing I can think of...  physically copying, renaming the problem image files. Do it one at a time so you can save Lightroom adjustment settings prior to deletion and reapply to new files. Don't sync new ones until you've deleted, cleared the old ones. See if they sync, then rename. If it works, you've solved the problem, but I admit it's an unsatisfactory workaround.  If it doesn't work it makes things seem so sketchy you might want to forward an image here or to a friend to see if it causes hangups.
Enthusiast ,
Apr 27, 2017 Apr 27, 2017
Again, thanks, joefry99.
I am certain you are on the right track. I have made copies both images,  in and outside lightroom and I have changed names. I am baffled.
I will send a PM ( to brag) if I figure it out.
vince
