In Adobe Presenter Video Express, is there a way to edit or fix a truncated slide when both presenter and slide are displayed without having to re-record the entire presentation? It happens to cut off either side of the slide regardless of which side to display the presenter.
I will move your question to the Presenter forum. This is the Captivate forum.
Since the presentation is in a video (MP4) I don't believe there is much editing you can do in APVE other than cropping out that portion of the video. However there are some things you can try.
Thank you for your reply. Good to know that I can edit the video externally through the source file. Since it didn't crop very well, I had to re-record the presentation. The good news, I only needed to re-record the PPT presentation and not the entire video/audio as I simply timed the slides with the original. It worked well. Thank you.
