Here is a pretty annoying issue I have when browsing for colors on the Adobe Color website:
When I find a color theme I want to save, clicking "save" opens a page for the saved color and exits the "explore" view. This is extremely annoying as I have to click back and perform the search (or scroll) all over again, every time I save a theme.
I just want to browse and save multiple color themes to try out in Illustrator. This should be an easy process, but it's absolutely not.
I couldn't find another way to submit this bug/request to Adobe so I really hope they see this?
I just realised that "save to library" doesn't even add the theme to my panel inside Illustrator. I have to click "appreciate". I don't think many first time users would guess that.
The only way to get my saved themes into Illustrator is to re-publish them as my own themes. I guess this is why there are so may duplicate themes on the site.
"Edit copy" and "save to library" is basically the same thing now.
I think there should be a way to use your saved themes inside Illustrator. This means you don't have to re-publish another user's theme (aka creating a duplicate) and you also make sure you have a personal copy of the theme in case the original creator decides to delete it.
Hello Hans,
Thanks for the feedback. I can tell you that both the items you pointed out are pretty high on our to-do list.
Shamit
For the second item, there is a workaround. If you have Adobe Illustrator CC you can find the color theme you created in the libraries panel ( Window > Libraries ).
Hi
Can you checkout the new Adobe Color Theme panel in Illustrator and share your feedback.
Shamit
Hello Hans,
The back button issues is now resolved. Can you check it out and share your feedback.
Shamit
Hi! I have also have a commentary on this UX. When I do a research, i found some color themes that are repeated and others that don't match on what i want, so i wish to have a button to dismiss that color theme result, and save search, is this a good idea? thanks
This is currently on do-list with our team, will get back to you once in effect.
