      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Captivate 2017 - Publish to exe does not work anymore?
Apr 21, 2017 Apr 21, 2017
Hi, i have a Captivate. 9 project which i can publish as windows exe in captiv. 9 without problems. When i try to publish it from captivate 2017 the same way (same settings) , the exe starts, but did not show me  the first screen. Only the table of Content is working, but i cant jump to any page from there.
any suggestions?
regards, andreas
843
Exe files need Flash Player, and can have issues with Flash Security settings, which means it is not sure that your problem is linked with 2017 or with another cause. Can you try a CP9 published exe to check that?
it is sure, like i said above, if i publish the same project as exe with captivate 9, it works like charm. same settings, same computer, same environment, same user, same time....
Sorry for my misunderstanding. Can you log a bug report?
Is not working for me as well for modules created with CP9 and imported into CP 2017.
However, I've opened and published for .exe first template module from the list below and is working fine. Also, module created from scratch is working fine after published as an executable file.
Adobe Employee ,
  Is it specific to the project that you are working on or with any project. If possible, please consider sharing the .cptx  file via hosting service (say dropbox) to adtiwari@adobe.com.
Aditya
Captivate Engineering Team
Apr 23, 2017 Apr 23, 2017
OK, i will send you a link via mail. thx in advance...
May 02, 2017 May 02, 2017
hi, i've send you the files on April 24th. Did you find something?
Kind regards, Andreas
Adobe Employee ,
Hi Andreas,
  I sent you a mail same day. I'm forwarding it again. Please check.
Aditya
May 03, 2017 May 03, 2017
OK, now i got, thanks a lot! Try this and report you.....
Help resources
