Hi, i have a Captivate. 9 project which i can publish as windows exe in captiv. 9 without problems. When i try to publish it from captivate 2017 the same way (same settings) , the exe starts, but did not show me the first screen. Only the table of Content is working, but i cant jump to any page from there.
any suggestions?
regards, andreas
Exe files need Flash Player, and can have issues with Flash Security settings, which means it is not sure that your problem is linked with 2017 or with another cause. Can you try a CP9 published exe to check that?
it is sure, like i said above, if i publish the same project as exe with captivate 9, it works like charm. same settings, same computer, same environment, same user, same time....
Sorry for my misunderstanding. Can you log a bug report?
Is not working for me as well for modules created with CP9 and imported into CP 2017.
However, I've opened and published for .exe first template module from the list below and is working fine. Also, module created from scratch is working fine after published as an executable file.
Is it specific to the project that you are working on or with any project. If possible, please consider sharing the .cptx file via hosting service (say dropbox) to adtiwari@adobe.com.
Aditya
Captivate Engineering Team
OK, i will send you a link via mail. thx in advance...
hi, i've send you the files on April 24th. Did you find something?
Kind regards, Andreas
Hi Andreas,
I sent you a mail same day. I'm forwarding it again. Please check.
Aditya
OK, now i got, thanks a lot! Try this and report you.....
