Please help me!
The system gave for my approved works total incorrect different keywords
I have a problem, when I submitting a work I can use my 40-50 tags of my keywords for the work, but when the picture gets approved, the first 6 keyword or some of, incorrectly, total different keywords are showing, not is mine, what I gave before, when I sent to the review process, why?
So when the files get approved, total different keywords are showing, not thoose which I gave them when I sent to the review process why?
Please help me!
How can I turn off the auto keywording tool?
I am waiting for your anwser.
King Regard,
Akos Horvath
Could you please explain how you fixed the issue or direct me to the post on Stock Contributors? I enter my keywords (I don't use lightroom) and then find the Beta system has added twenty more, many of which are not at all applicable. I'd like to turn off the auto keyword feature.
Thank you!
Have you saved the keywords as part of the image file metadata before you upload it?
No, I don't use metadata for my works I always writing the keywords on the online system, on my desktop I wrote it down on a txt word documentum file for a photo series or single image (the best 40 keywords), and then I copy paste to the online system my keywords for the theme, I use it for Shutterstock also and no problem, so the problem here if I deleted the the auto keywording tool suggested words, then I paste my words on it, but if it approved, the system gave me total different keywords , why?
or when I deselect all the system was changing the keywords
On Shutterstock nothing like this happaning...
Please help me
King Regard,
Akos Horvath
Please help me
King Regard,
Akos Horvath
2017-04-21 19:52 GMT+02:00 DavidM7d <forums_noreply@adobe.com>:
created by DavidM7d <https://forums.adobe.com/people/DavidM7d> in *Adobe
Stock Contributors* - View the full discussion
<https://forums.adobe.com/message/9469884#9469884>
Hi Akosh. This might be one for the technical guys at AS. I'm guessing it has something to do with your copy and paste process. Do you enter the keywords separately into separate boxes or do you paste the whole lot into one box?
I save all of mine to the metadata now. So much quicker for uploading, and for future reference.
Have a look at this previous discussion.
David, how to save the keywords and Title for metadata? If I have for exaple 30 photos the same theme (yoga instructor), then I get able to save it for one time all the keywords , or must I do it for single to single until reaching the 30 photos?
And if the system shows your keywords from the metadata on the online submitting process, then is it change your keywords or not?Which program do you use it, how can do it?
Hi Akos,
You can write keywords to batches of images in Lightroom, if that is what you are using, and then save to the metadata. Here's a good run-through:
How to use keywords in Lightroom
You can't do titles that way, they have to be entered each time when you do the upload (although you could copy and paste, rather than re-type each time). I prefer to make titles slightly different, if possible.
Many thanks, but I don't need metadata, the problem is solved I discovered it on the online adobe stock contributor system
You know I only work for the to best 2 agency Shutter and Adobe Stock
OK, good news.
Thank you!
You can find this option : " Erase all keywords" First of all select all the works then click it, " Erase all keywords" then paste your keywords, when you submitting then you see at the review process, your keywords again and if the same keywords still, that you gave before, it will be ok I think.
Akos
Thank you! That is exactly what I needed to know.
