I recently bought a 27" 5K iMac, which is a great computer so far. The monitor is amazing but it's so detailed that when I create a path in InDesign, the path is so thin that it gets lost in the image and I sometimes have to turn off the image layer so I can find the path. Is there a way to make the path (or the handles) thicker or a color so I can see it (them) easier?
I'm using CC 2014 but would upgrade to 2017 if I had to.
Lloyd
You can stroke a path with a Photoshop tool like a brush. Here I added an empty layer and stroked a path on it using a 4px hard red brush
JJMack,
Thanks for the tip. I already know how to stroke a path...what I'd like to do is make the path thicker (or a color) while I'm creating it so I can see it better, not after I'm finished creating it.
Lloyd
How are you creating the path. Photoshop tools like the Pen tool tries to create contrast between the path and document. Rubber band mode seems to be OK with most colors. However at times it can be hard to see with some images content. Adding a temp work color layer at some lower than 100% opacity can help
I've never had a problem until I bought this 5K iMac. The screen resolution is so high that it makes the path extremely thin, and right now I'm working with an image that has both dark and light areas. It's not so much the color but it's the thickness...or, I should say, thinness...of the path. Plus, it's difficult to click specifically on the handles because of the high resolution. I guess it's just a good problem to have.
Small pixels and old eyes tell me about it... Dell now has an 8K display with 280dpi pixels.....
YIKES!!! Actually, I might look into that. hehe...
Actually, not for $4,000+ I won't!
To make the paths more visible, I add a Color Fill Layer with some sort of tan/olive color, set to 15% opacity. I keep the layer hidden when I'm not editing paths, making it visible while editing. It ghosts out the image enough to make the paths easier to see, and still see the image.
I tend to use shape layers and use a stroke only. That way you can increase the thickness and color on the fly.
