Function equivalent to "Break Link" in the Edit-->Links dialog box
Participant ,
Apr 21, 2017 Apr 21, 2017
Hello fellows,
I wonder if there is an API (in framescript/extendscript) for breaking a link to an imported inset file (Excel sheet, Visio, etc).
Roman
Scripting
404
Community Expert , Apr 23, 2017 Apr 23, 2017
This won't work for OLE (linked) objects. The InsetFile property for these is always an empty string. These kinds of links are not exposed to the FDK, ExtendScript, or FrameScript. As far as I know, there is no way to break this kind of link programmatically.
Advocate ,
Hi Roman,
With a simple script you can find the inset to be unlinked and set its InsetFile property to an empty string. That should do the trick, I think.
Ciao
Jang
Participant ,
Hi Jang,
I appreciate your input! No wonder I didn't find any function related to that. Following your suggestion, I came up with the following code.
The problem is that for a reason that is unclear to me, I can't retrieve the InsetFile path using alert() and can't make it null. The alert dialog box that pops up contains no value. What am I missing?
var doc= app.ActiveDoc;
DisconnectGraphics(doc);
function DisconnectGraphics(doc)
   var graph = doc.FirstGraphicInDoc;
       while (graph.ObjectValid()) {
            if ( graph.type == Constants.FO_Inset ) {
               alert(graph.InsetFile);
               graph.InsetFile = "";
         graph = graph.NextGraphicInDoc;
Participant ,
Hi Rick,
Thank you for your response!
I was afraid that Adobe didn't cover the OLE2 use case...
I'll check if this can be done with AutoIt.
Best Wishes,
Roman
