If I use the repairing tool in photoshop, a crinkly edge arises around the select place. What can i do?
You could post screenshots (that include the pertinent Panels, Toolbox etc.) to clarify what you are talking about.
It does not look so extreme. If I use themending tools, this pixelated edgerecently appears around the choice. Thislooks very squalid and I do not know inwhich it lies. I have tried out a little bit, but have found nothing. Then I havewatched with which tools I the usualretouching, until I have found thesolution, can continue. The Copy stampis on a continuing basis nothing for me, it simply lasts too long. Then I have triedout the Repairing paintbrush in the mode "contents-based". It is not themost optimum one. So I have put the mode on "approximate value" and it happened the same one. The marked choices have also had this pixelated edge.
c.pfaffenbichler​ Wenn du Deutsch sprichst, wäre das etwas einfacher sich darüber aus zu tauschen.
You seem to have selected the Brush Tool to mark the relevant parts, but that means the actual Tool you used and its settings (as indicated in the Options Bar) are not clear.
I do not use the German version of Photoshop and the preferred language on this Forum is English.
I have only selected this to mark the places. Otherwise, I use for the retouching the tool which looks like a plaster. I have belonged that it can be no information in the file. But I don´t know like I should solve this.
Do you mean the Healing Brush Tool or the Spot Healing Brush Tool?
Normally I use the tool which is choosen in the tool box on the left site.
