After_EffectsCC (version 14.1.0.57) Can't use Mercury GPU Acceleration on Win(10.0.14393 Build 14393)
Apr 16, 2017 Apr 16, 2017
I am unable to use Mercury GPU Acceleration. The problem started when I converted a piece of Footage from Premiere Pro CC into a After-effects Composition I got the following message:
Error Message: This project was last used with Mercury GPU Acceleration (OpenCL), which is not
avaliable on this system. Mercury Software Only will be Used.
Since the initial error I check and the Mercury GPU Acceleration is not avaliable on several different project files.
I have tried reloading the after-effects project. I have tried resetting the After-Effect Preference file. I have also updated my video card drivers. I have checked and it appears I have to most upto date verison of After-Effects. Hardware specs are listed below:
SystemVideo Card
Windows 10 Home Version: 1607,
OS Build: 14393.1066
Processor Intel(R) Core(TM) i7 CPU 860 @2.80GHz 2.80 GHz
Installed Memory (RAM) 16.0 GB
System Type: 64-bit Operating System, x64 Based Processor
My Main Drive is a Samsung SSD Drive PRO 512GB
  AMD Radeon HD 5800 Series
                      Radeon Settings Version - 2016.0226.1531.27895
                      Driver Packaging Version - 15.301.1901-160226a-299900E
                      Provider - Advanced Micro Devices, Inc.
                      2D Driver Version - 8.1.1.1533
                      Direct3D® Version - 9.14.10.1171
                      OpenGL® Version - 6.14.10.13417
                      OpenCLâ„¢ Version - 2.0.4.0
                      AMD Mantle Version - 9.1.10.99
                      AMD Mantle API Version - Not Available
                      AMD Audio Driver Version - 10.0.0.2
Any suggestions are greatly appreciatated. Thank You,
767
Apr 19, 2017 Apr 19, 2017
Have you ever been able to use acceleration in AE on this system?
Have you tried updating your GPU driver?
Have you tried today's update to AE?
Apr 20, 2017 Apr 20, 2017
Good afternoon,
Yes, previously I was able to use acceleration in AE on this system.
I have updated the graphics card driver here in April.
I am updating AE as I type.
I saw something some one else had posted about this issue, I will need to go find the link and review it further.
Thanks for your response.
John
Engaged ,
Apr 21, 2017 Apr 21, 2017
Just out of curiosity are you using Lumetri with imported LUT files?
I wasted 2 hours of my shift finding out that if a custom LUT file path is broken [ in my case because a network drive wasn't mounted],
AE responds by showing you this error until you turn off all instances of Lumetri / relink.
Trying to post about it to save someone some time, and yours is the closest Ive found.
Apr 22, 2017 Apr 22, 2017
That sounds awful! Thank you for sharing the issue and how to fix it. Have you filed a bug with Adobe about it? I'm sure they could figure out a better way to handle the error. Adobe.com/go/wish is the bug report form.
Engaged ,
Apr 25, 2017 Apr 25, 2017
Thanks Szalam- will do that now.
But oops,  It seems the Adobe site is having more 404 issues?
Feature Request/Bug Report Form
Good afternoon,
I am afraid your above my level of knowledge good sir. I haven't used Lumetri. But, I do appreciate your response. I'm glad your figured out the problem sorry it took so long.
Adobe Employee ,
May 23, 2017 May 23, 2017
Hi John,
Does this mean you have GPU acceleration working once more? Please let us know and if you need more help.
Kevin
