We are planning to use After Effects for automatic rendering and thus run it from command line.
In order to render the content faster we use multi-machine mode ( as described here: Automated rendering and network rendering in After Effects ).
Now we need to make it automatically - run it from command line by a script (without UI).
How can we do it?
Any method or tip helps
the link you have included seems to have all the info.
what "missing links" do you have in the process?
On Mon, Apr 3, 2017 at 4:55 PM, erezo41320762 <forums_noreply@adobe.com>
Hey there!
Have you gotten an answer to this? There are certainly some ways to make this kind of thing happen. I have an Automator droplet I've created on my Mac that accepts an AE project and runs the AERender application.
It looks like this:
The code is this:
on run {input, parameters}
set aeRender to (quoted form of ("/Applications/Adobe After Effects CC 2017/aerender"))
set aepInput to (quoted form of (POSIX path of input))
tell application "Terminal"
activate
--tell application "System Events" to keystroke "n" using {command down}
do script (aeRender & " -project " & aepInput)
end tell
end run
Reading Material:
There are then ways to make folders do things, but I'm thinking maybe that would be through a PHP watcher app.
Hi guys,
Thanks for your replies.
I found some way to make the process work automatically and now have new issue:
Network rendering issue - not all agents are working
Please help.
Thank you.
Erez
