hi every body..
I've searched long time...
I 'm working on html 5 canvas project using adobe animate cc. I 've mp4 video on the timeline and I have some content on the timeline.
The question is How can I make the timeline start playing when I click on the play button of the video ??
I've used the following, but it did not work...
var pos = 0;
// Assign an ontimeupdate event to the video element, and execute a function if the current playback position has changed
vid.ontimeupdate = function() {myFunction()};
function myFunction() {
pos = Math.round(vid.currentTime*24);
// where 24 is the current frame rate
inputTxt.value = pos;
this.stop(pos+1);
Event handlers default to executing in the global window context. Yes, this was a very poorly thought out design decision, but now we're stuck with it.
To force a function to execute in a specific context, you have to use .bind() on it.
Sticking an alert(this); in your event handler would be enlightening.
A little correctness:
this.play(pos+1); instead of this.stop(pos+1);
Neither are correct. Only gotoAndStop() and gotoAndPlay() take frame numbers.
I've done that but still not work.. the play head dos not move ..
When I add
alert(this);
inside function myFunction() .. I get [Object window ] message..
The question still How Can I refer to the timeline to play the play head??
