I have some line art on which I copied over to Illustrator and performed an Image trace (black and white). Soon, I was back in Photoshop and pasted the Vectors in as a smart object. All looked well. Then, I noticed something wrong. If I put a white layer behind the Smart object, the lines look black as it should. But it isn't. I put a Black layer behind it and it is obvious that the smart object has a Grey color.
The gray just doesn't work. I need black color.
I'm new to Illustrator. I just got it for the tracing. The product I am producing seems to be correct. It at least appears to be all black. The Opacity is 100.
The fill and strokes are both black. I am doing a Black and White trace. All this at least appears to go into Photoshop properly except the fill color is grey.
I have not found any settings to fix this. Suggestions!
Oh yes. Its not a grayscale image. Its color, I just have a line layer over top, like a cartoon
Or create your Ai file in RGB mode, checking that Black is indeed 0 0 0.
It depends what mode this .ai file is using
If it's CMYK, you might have it set to Process Black 0 0 0 100 which when imported into Photoshop translates to R 35 G31 B32
If it RGB, the RGB would be 0 0 0 or Photoshop Black.
So if your ai document must be CMYK, click on your black foreground swatch and set the Color Picker like so, before creating your artwork for Photoshop.
and of course I will leave you with this: http://www.andrewkelsall.com/the-professional-designers-guide-to-using-black/
Thank you
My PS original file was a RGB. When opening Illustrator, it was defaulting to CYMK and I did not notice it. I retested and the CMYK just isn't working.
So I tried it all again using RGB in Illustrator. That worked.
Now to go fix the hundreds of Images that are screwed up 🙂
Glad to hear you found out what went wrong. I'm surprised Ai CS6 would convert your mode from RGB to CMYK before asking if that is what you want to do.
Perhaps look at your Color settings (Shift + Ctrl +k) and see what the conversion policies are or Reset Warnings in your Preferences.
As far as Ai CC goes, an RGB at file is kept at RGB when opened again.
The Illustrator file is a separate file, it has its own color mode. You can paste or place RGB content into a CMYK file and it's still CMYK.
You can, however, open an RGB image in Illustrator, and then the file will remain RGB.
There is, as you've learned, a difference between 100K black and rich black (4C black). You might want to go into Illustrator preferences and set Appearance of black to "display all blacks accurately". This will display 100K black as what it is - a dark charcoal gray.
The default setting is "display all blacks as rich black" and you can't tell them apart on screen.
Photoshop doesn't have this option and will always (in CMYK content) display all blacks accurately.
