I've been working on tracking down some funkiness with cfcharts. specifically their memory use. This is what I've noticed about it in CF2016 Update 3.
I’ve created some code to test some stuff. Feel free to play around with it.
<!--- get our CF_Chart_CacheManager --->
<cfscript>
/* what am I looking for */
chartCacheName='CF_Chart_CacheManager';
/* gets all the Cache Managers in EHCache */
cacheManagers = createObject('java', 'net.sf.ehcache.CacheManager').ALL_CACHE_MANAGERS;
for (item in cacheManagers) {
writeOutput('EHCache Manager Instance Name:' & #item.getName()# & '<br />');
/* pluck our Chart Cache */
if ( item.getName() == chartCacheName ) {
cm = item;
thisCache = cm.getCache(chartCacheName);
if(!isdefined('thisCache')) {
WriteOutput("CF_Chart_CacheManager doesn't exist yet.");
abort;
/* override configuration settings */
//thisCache.getCacheConfiguration().setTimeToLiveSeconds(30);
//thisCache.getCacheConfiguration().setTimeToIdleSeconds(30);
//thisCache.getCacheConfiguration().maxElementsInMemory(5);
</cfscript>
<!--- output some stats --->
<cfoutput>
<ul>
<li>Count: #NumberFormat(thisCache.getStatistics().getSize())#</li>
<li>Max Elements In Memory: #numberformat(thisCache.getCacheConfiguration().getMaxelementsInMemory())#</li>
<li>Disk Persistance: #YesNoFormat(thisCache.getCacheConfiguration().isDiskPersistent())#</li>
<li>Eternal: #YesNoFormat(thisCache.getCacheConfiguration().isEternal())#</li>
<li>Overflow To Disk: #YesNoFormat(thisCache.getCacheConfiguration().isOverflowToDisk())#</li>
<li>Time To Live: #NumberFormat(thisCache.getCacheConfiguration().getTimeToLiveSeconds())#</li>
<li>Time To Idle: #NumberFormat(thisCache.getCacheConfiguration().getTimeToIdleSeconds())#</li>
<li>Exists: #YesNoFormat(cm.cacheExists(chartCacheName))#</li>
</ul>
</cfoutput>
<!--- chart it, ironic --->
<cfchart format="png" chartwidth="600">
<cfchartseries type="bar" colorlist="##00FF00,##CC0000,##CCFF00,##FF0000,##CC0099,##0000FF,##FFFF66,##FFFFFF">
<cfchartdata item="Count" value="#thisCache.getStatistics().getSize()#" />
<cfchartdata item="Hits" value="#thisCache.getStatistics().cacheHitCount()#">
<cfchartdata item="Disk Hits" value="#thisCache.getStatistics().localDiskHitCount()#" />
<cfchartdata item="Memory Hits" value="#thisCache.getStatistics().localHeapHitCount()#" />
<cfchartdata item="Memory Misses" value="#thisCache.getStatistics().localHeapMissCount()#" />
<cfchartdata item="On Disk" value="#thisCache.getStatistics().getLocalDiskSize()#" />
<cfchartdata item="On Heap" value="#thisCache.getStatistics().getLocalHeapSize()#" />
<cfchartdata item="Off Heap" value="#thisCache.getStatistics().getLocalOffHeapSize()#" />
</cfchartseries>
</cfchart>
<!--- get methods we can call --->
<cfset WriteDump(thisCache.getStatistics())>
<!--- dump all the keys in this cache --->
<cfset WriteDump(thisCache.getKeys())>
I put in a request on the ColdFusion Slack team Adobe channel for someone at Adobe to take a look.
Can you submit a bug report for the various caching issues you've identified: ColdFusion Issue Tracker?
-Carl V.
I will, I'm just trying to fully understand what's happening under the hood and put together some reproducible examples. I probably need another day to put something together.
Also the NAME attribute doesn't work at all when chart type is flash or html. I've created a bug report: CF-4198527
The memory leak issue with cfcharts eats 12MB of server RAM every time I refresh a page with 8 charts in it. The CF process went from 1GB (physical RAM) to over 2GB after a couple hours of just me refreshing the page - after rebooting it from when it crashed earlier for the same reason! (Java out of memory error). I cannot use CF2016 in production in this state.
I also don't like Zingcharts, although I'm about 4 years late to this party! They look awful compared to Webcharts3D, which is also smarter at formatting pies, bars, legends and tooltips.
So basically everything in my application to do with charts is broken functionally and aesthetically when upgrading to CF2016.
It appears that each Ehcache ZingCharts object uses a lot of memory. If you have the "Maximum number of cached images" set to a high number (500+), this can eat up lots of memory and never let it go. Ehcache has a setting called "timeToLiveSeconds", but it doesn't do what you think it does. It simply invalidates the object, it does not remove it from memory. So if you have 1000 objects cached in Ehache, it will use all the memory for those 1000 objects, even if you have a short "timeToLiveSeconds". The only way Ehcache starts to evict objects from memory in CF is when you hit the "Maximum number of cached images". Ehcache does have a method called evictExpiredElements() that could evict them, but there is no process to call this. This is by design for performance.
I was able to create a workaround for the memory issue, at least in terms of it not using all the memory. This doesn't resolve the other issues, but keeps the server from crashing. You should set the "Cache type" to Memory and set a low "Maximum number of cached images". I set mine to 100.
CFAdmin doesn't set the Ehcache timeToLiveSeconds, but you think it would with the setting "Time-to-Live of each chart in seconds", so you can ignore that. That setting only relates to "Cache type": Disk. If you have a "Cache type":
Interesting, Neo. As an experiment I set cache type to Memory (previously disk) and used the default of 50 for the cache. I restarted the CF service for good measure and ran my cfchart script. CF generated temp files on disk for each chart! That's not what I call a memory cache.
Reloading the page constantly ate away at the server's memory. An additional 700MB was consumed by coldfusion.exe in 10 minutes. 😞
Yeah, I think it has to write to disk to server them up through the CFFileServlet? The time-to-idle will still delete the ones on disk at that amount of time, even if Cache Type is Memory. I've been running some production traffic over my CF2016 install and have been monitoring it with the code below. My 100 "cached" charts seem stable around "On Heap Bytes: 669,560". I wonder if the type of charts matters? Also, if you're running a big loop, it might not have time to do a garbage collection. Might want to force one.
Update 4 just came out today, I don't think it fixes some of my issues, but maybe its better since they did address some Chart issues. I'm going to apply it and see what happens.
<cfscript>
/* get an instance of Ehcache */
Ehcache = CreateObject('java', 'net.sf.ehcache.CacheManager');
/* get cacheManager instance */
cm = Ehcache.getCacheManager('CF_Chart_CacheManager');
/* this call will initialize */
cmStatus = cm.getStatus();
/* get cache */
thisCache = cm.getCache('CF_Chart_CacheManager');
</cfscript>
<cfoutput>
<ul>
<li>On Heap: #NumberFormat(thisCache.getStatistics().getLocalHeapSize())#</li>
<li>Off Heap: #NumberFormat(thisCache.getStatistics().getLocalOffHeapSize())#</li>
<li>On Heap Bytes: #NumberFormat(thisCache.getStatistics().getLocalHeapSizeInBytes())#</li>
<li>Off Heap Bytes: #NumberFormat(thisCache.getStatistics().getLocalOffHeapSizeInBytes())#</li>
<li>On Heap Hit Count: #NumberFormat(thisCache.getStatistics().localHeapHitCount())#</li>
<li>Cache Evict Count: #NumberFormat(thisCache.getStatistics().cacheEvictedCount())#</li>
<li>Cache Expired Count: #NumberFormat(thisCache.getStatistics().cacheExpiredCount())#</li>
<li>Max Bytes Local Heap: #NumberFormat(thisCache.getCacheConfiguration().getMaxBytesLocalHeap())#</li>
<li>Max Bytes Local Heap: #NumberFormat(thisCache.getCacheConfiguration().getMaxBytesLocalOffHeap())#</li>
<li>Max Bytes Off Heap: #NumberFormat(thisCache.getCacheConfiguration().getMaxMemoryOffHeap())#</li>
</ul>
</cfoutput>
Update 4 doesn't fix the memory leak issue unfortunately. Adobe are still working on it and have asked me to send them some dumps.
My cfchart loop is just javascript reloading the page, so there's never a build up of requests, and no one else is using the dev server. I don't think garbage collection is supposed to wait until there are no requests, otherwise GC would never happen on a busy production server.
This won't help your performance issue, but I highly recommend looking at the zingchart documentation to get the look and feel you want. Relying on cfchart is probably a mistake, but understanding that recoding may not be an option, using the styling capabilities will help a lot.
