GREP Question
Apr 25, 2017 Apr 25, 2017
Have a job - example attached where the Tel No has a paragraph style which gives it a rule to divide entries in a directory.
However, in some cases, where the TelNo style is immediately followed by the Category style, I want to apply a TelNo with no rule style.
Is there a GREP or other method to do this throughout the book or do I need to do it manually?
Example attached
Scripting
937
Engaged ,
Try tis code!!!
var myDoc = app.activeDocument;
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.appliedParagraphStyle = "H1"; // Change Your style
var Found = app.activeDocument.findGrep();
for (i=0; i<Found.length; i++)
if (Found.paragraphs.previousItem(Found.paragraphs[0]).appliedParagraphStyle == app.activeDocument.paragraphStyles.item("Ph_No_Rule")) // Change Your style
// Remove Rule
  Found.paragraphs.previousItem(Found.paragraphs[0]).ruleBelow = false;
Prabu
Prabu
Design smarter, faster, and bolder with InDesign scripting.
Apr 26, 2017 Apr 26, 2017
Thanks for your help - really appreciate it - throwing up a syntax error though - see image.
I'm a bit of a novice at this level so please bear with me...Screen Shot 2017-04-26 at 11.00.49.png
When I remove the offending quote marks I get the following errorScreen Shot 2017-04-26 at 11.04.31.png
Guide ,
Recopy Anand script and change the two paragraph style names again..don't delete any quotes
Make sure both are not in STYLE GROUP
This is my script where Tel is the first para style and TelNoRule is the second.
app.findGrepPreferences.appliedParagraphStyle = “Tel”;
var myPrevious = Found.paragraphs.previousItem(Found.paragraphs[0] );
        if (myPrevious.isValid && myPrevious.appliedParagraphStyle.name == “TelNoRule”)
            Found.paragraphs.previousItem(Found.paragraphs[0] ).ruleBelow = false;
Guide ,
It is working fine here..
Make sure your style look like this..
Not this
Engaged ,
Its working fine here. i don't get any error message.
thanks
Prabu
Thanks again,
My styles aren't in a group - I'm not sure what I'm doing wrong as it looks the same as yours.
To run the script I'm using TextEdit to create the file and dropping into Scripts Panel in ID folder. Running it from there - is that correct?
Engaged ,
save the .jsx format or run the Extend Script toolkit
thanks
Prabu
Engaged ,
Prabu
Engaged ,
Hi, Any updates on tis...?
Prabu
I've had to crack on with some other work but I'm using the toolkit now - I'll try again later and let you know.
Thanks again!
Engaged ,
        if (myPrevious.isValid && myPrevious.appliedParagraphStyle.name == "Ph_No_Rule") // Change your style
Prabu
Prabu
Participant ,
Try this;
Straight double quotation marks
