Artifacts from video player controls display on upper layers of multi-state object
Apr 25, 2017 Apr 25, 2017
I have created an ePub file in InDesign CC 2017 which contains MP4 video content on a lower state of a multi-state object. The video controls (circle with triangle play button and rectangular bar containing the timeline slider, full screen button, etc...) are appearing on the object states above the state containing the video content.
It's important to note that this ONLY happens on iPads. I've tried several iOS ePub readers (iBooks and Adobe Digital Editions and the result is the same). The ePub functions correctly on MACS and PCs. I am also able to export to an SWF file and play the document from a browser without problems.
Image 1 - Video content (on lower state of multi-state object)
Image 2 - Artifact from play button of video content (on upper state of multi-state object)
Image 3 - Artifact from control bar of video content (on upper state of multi-state object)
Additionally, I have tried setting the controller to 'none' in the interactive/media panel and the controls appear to be generated automatically regardless of the setting in InDesign. I have also tried exporting the video as a Snippet, editing the code to make the controls not appear, and placing the edited snippet in the document. This also did not work.
Thank you for any insight that would help me resolve this issue.
689
Community Expert , Apr 26, 2017 Apr 26, 2017
Are you able to change your approach away from summoning a different STATE to hyperlinking to a different PAGE?
Did you add those items on top of the video? Have you tried using a poster image instead?
Thanks Bob. If I'm understanding you're question correctly, I did not add the controller elements. They appear to be generated automatically when the ePub is opened in an ePub reader in iOS. As for the Poster Image, it is set to "from current frame' and I just scrolled forward to an appropriate part of the video. Are you suggesting I try using an image?
Thanks Again
It’s worth a try but this sounds like a reader bug.
Thanks for the suggestion Bob. I wanted to let you know that using a poster image did not solve the problem. I agree that this sounds like a reader bug. iBooks on an iPhone has the same issue.
Mike Witherell
Yes Micheal. That is my workaround. Unfortunately on an a tablet it becomes a page that can be accessed by swiping which is not ideal but it will have to do because I'm not sure how to pursue this with Apple. Thank you
I’m glad that workaround was useful.
Oct 09, 2017 Oct 09, 2017
I have exactly the same problem... and it's driving me mad! Did you manage to find a solution?
Mar 29, 2018 Mar 29, 2018
Hi, any news about this problem?
