I try to make camera movement with null and 3D layer. I add null object and camera above all layers. But, When I add 3D Layer for all layers, the bottom layer look like top layer
I'm sorry my english is bad. please watch the video if you don't understand.
Layers get interved/reversed when add 3D layer - After Effects please help me - YouTube
Definitely something is wrong here. have you set expression of any kind in these layers? if not, can't be sure why is this happening. this could be a bug of some sort try this just for testing:
1. when you create your camera choose a 50 mm camera preset and see if that's works
2. first set your layers to 3D then add a camera. no null . see if that works.
if it's still happening this way, try to create a new composition and copy the layers there and see. still no dice?, close Ae and upon launch rese
...Copy link to clipboard
When you have problems with a layer the first thing to do is to select the layer or layers giving you problems and then press the U key twice. This will reveal all modified properties. I would guess that the layers are in the same z space or the z position is not correct. Let us know if this solves your problem.
I'm a newbie here, please tell me how to adjust the z-value of the layer.
thank you sir.
if it's still happening this way, try to create a new composition and copy the layers there and see. still no dice?, close Ae and upon launch reset your preferences: Reset After Effects Preferences
woohoooo . thanks bro. it's work, after i reset my after effects preferance it still not work for my current project, but its work with my new project.
thank you
You're welcome. guess this one will be tagged as Ae's Oddities.
