Hello everyone,
i feel my premiere pro 2017 a bit slow, some lags when i move a clip or move the cursor in the timeline, however i have a not too bad computer
i7 Quad Core Processor 6820HK (2.7GHz, 3.6GHz Turbo)
64GB HyperX IMPACT 2133MHz SODIMM DDR4 (4 x 16GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
HDD 512Gb SSD
I run Premiere pro on Windows 10 64bit
Premiere pro is installed on the boot disk
The project I work on is on an external hard disk USB3 (not SSD)
Would do you have any recommendation to set window or Premiere to have better performance ?
Cheer
Pierre
[Moderator note: moved to best forum]
Hi Pierre.
I'm suspicious of the external drive. USB3 is fine but if the disc is only spinning at 5400rpm or has other low specs, that could cause the problem.
Martyn
thank you, i'll try with a better had disk
