Modification need for AddGuides.jsx
Guide ,
Apr 26, 2017 Apr 26, 2017
The AddGuides.jsx is an inbuild script in Indesign. It will open the UI and set as our desired input.
Is it possible to run this script without UI? I meant I need to add guides with default value in UI.
Challenges:
1) I can use app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;  but it only hide the UI
2) How to disable the onclick function for OK button? So that it will run without asking UI.
//AddGuides.jsx
//An InDesign JavaScript
@@@BUILDINFO@@@ "AddGuides.jsx" 3.0.0.0 14 December 2009
//This script draws guides around the selected object or objects.
//Choose Visible Bounds to consider the stroke weight of the paths when placing the guides,
//or choose Geometric Bounds to ignore the stroke weight when placing the guides
//Choose Each Item to position the guides around individual items in the selection,
//or Entire Selection to position the guides around the selection as a whole.
//This script also includes an alternative dialog box for the script. This dialog was
//created using the ExtendScript ScriptUI component. ScriptUI lacks some of the useful
//controls that the InDesign dialog object offers, but it can be used to create interactive
//dialog boxes and panels.
//For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
//Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com.
main();
function main(){
  //Make certain that user interaction (display of dialogs, etc.) is turned on.
  app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
  var myObjectList = new Array;
  if (app.documents.length != 0){
  if (app.selection.length != 0){
  for(var myCounter = 0;myCounter < app.selection.length; myCounter++){
  switch (app.selection[myCounter].constructor.name){
  case "Rectangle":
  case "Oval":
  case "Polygon":
  case "TextFrame":
  case "Group":
  case "Button":
  case "GraphicLine":
  myObjectList.push(app.selection[myCounter]);
  break;
  if (myObjectList.length != 0){
  var myOldXUnits = app.documents.item(0).viewPreferences.horizontalMeasurementUnits;
  var myOldYUnits = app.documents.item(0).viewPreferences.verticalMeasurementUnits;
  app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
  app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
  myDisplayDialog(myObjectList);
  //Comment out the previous line and uncomment the following line to use a ScriptUI dialog.
  //myDisplayScriptUIDialog(myObjectList);
  app.documents.item(0).viewPreferences.horizontalMeasurementUnits = myOldXUnits;
  app.documents.item(0).viewPreferences.verticalMeasurementUnits = myOldYUnits;
  else{
  alert ("Please select a page item and try again.");
  else{
  alert ("Please select an object and try again.");
  else{
    alert ("Please open a document, select an object, and try again.");
function myDisplayDialog(myObjectList){
  var myRangeButtons, myBasedOnButtons;
  var myLabelWidth = 100;
  var myDialog = app.dialogs.add({name:"AddGuides"});
  with(myDialog){
  with(dialogColumns.add()){
  with(borderPanels.add()){
  staticTexts.add({staticLabel:"Add Guides At:"});
  var myTopCheckbox = checkboxControls.add({staticLabel:"&Top", checkedState:true});
  var myLeftCheckbox = checkboxControls.add({staticLabel:"&Left", checkedState:true});
  var myBottomCheckbox = checkboxControls.add({staticLabel:"&Bottom", checkedState:true});
  var myRightCheckbox = checkboxControls.add({staticLabel:"&Right", checkedState:true});
  var myXCenterCheckbox = checkboxControls.add({staticLabel:"&Horizontal Center", checkedState:true});
  var myYCenterCheckbox = checkboxControls.add({staticLabel:"&Vertical Center", checkedState:true});
  var myXPointCheckbox = checkboxControls.add({staticLabel:"Path Point Hori&zontal Anchor", checkedState:false});
  var myYPointCheckbox = checkboxControls.add({staticLabel:"Path Point Verti&cal Anchor", checkedState:false});
  staticTexts.add({staticLabel:"Add Guides Around:"});
  with(myRangeButtons = radiobuttonGroups.add()){
  radiobuttonControls.add({staticLabel:"Each &Object", checkedState:true, minWidth:156});
  radiobuttonControls.add({staticLabel:"Entire &Selection"});
  with(dialogRows.add()){
  staticTexts.add({staticLabel:"Guides Based On:"});
  with(myBasedOnButtons = radiobuttonGroups.add()){
  radiobuttonControls.add({staticLabel:"&Geometric Bounds", checkedState:true, minWidth:160});
  radiobuttonControls.add({staticLabel:"V&isible Bounds"});
  staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
  var myXOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
  staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
  var myYOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
  myReturn = myDialog.show();
  if (myReturn == true){
  //Get control values from the dialog box.
  var myTop = myTopCheckbox.checkedState;
  var myLeft = myLeftCheckbox.checkedState;
  var myBottom = myBottomCheckbox.checkedState;
  var myRight = myRightCheckbox.checkedState;
  var myXCenter = myXCenterCheckbox.checkedState;
  var myYCenter = myYCenterCheckbox.checkedState;
  var myXPoint = myXPointCheckbox.checkedState;
  var myYPoint = myYPointCheckbox.checkedState;
  var myBasedOn = myBasedOnButtons.selectedButton;
  var myRange = myRangeButtons.selectedButton;
  var myXOffset = myXOffsetField.editValue;
  var myYOffset = myYOffsetField.editValue;
  //Remove the dialog box from memory.
  myDialog.destroy();
  if(myTop+myLeft+myBottom+myRight+myXCenter+myYCenter+myXPoint+myYPoint !=0){
  myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList);
  else{
  alert("No guides were specified.");
  else{
  myDialog.destroy();
//ScriptUI version of the above dialog box.
function myDisplayScriptUIDialog(myObjectList){
  var myBasedOn, myRange;
  var myDialog = new Window('dialog', 'AddGuides');
  with(myDialog){
  alignChildren = 'fill';
  var myGuideTypesPanel = add('panel', undefined, "Add Guides At:");
  with(myGuideTypesPanel){
  orientation = 'column';
  alignChildren = 'left';
  margins = [12, 16, 12, 6];
  spacing = 4;
  myDialog.myTopCheckbox = add('checkbox', undefined, "Top");
  myDialog.myTopCheckbox.value = true;
  myDialog.myLeftCheckbox = add('checkbox', undefined, "Left");
  myDialog.myLeftCheckbox.value = true;
  myDialog.myBottomCheckbox = add('checkbox', undefined, "Bottom");
  myDialog.myBottomCheckbox.value = true;
  myDialog.myRightCheckbox = add('checkbox', undefined, "Right");
  myDialog.myRightCheckbox.value = true;
  myDialog.myXCenterCheckbox = add('checkbox', undefined, "Horizontal Center");
  myDialog.myXCenterCheckbox.value = true;
  myDialog.myYCenterCheckbox = add('checkbox', undefined, "Vertical Center");
  myDialog.myYCenterCheckbox.value = true;
  myDialog.myXPointCheckbox = add('checkbox', undefined, "Path Point Horizontal Anchor");
  myDialog.myXPointCheckbox.value = true;
  myDialog.myYPointCheckbox = add('checkbox', undefined, "Path Point Vertical Anchor");
  myDialog.myYPointCheckbox.value = true;
  var myGuideLocationPanel = add('panel', undefined, "Add Guides Around:");
  with(myGuideLocationPanel){
  margins = [12, 14, 12, 6];
  spacing = 4;
  myDialog.myEachObjectRadioButton = add('radiobutton', undefined, "Each Object");
  myDialog.myEachObjectRadioButton.value = true;
  myDialog.myEntireSelectionRadioButton = add('radiobutton', undefined, "Entire Selection");
  var myGuidesBasedOnPanel = add('panel', undefined, "Add Guides Based On:");
  with(myGuidesBasedOnPanel){
  spacing = 4;
  myDialog.myGeometricBoundsRadioButton = add('radiobutton', undefined, "Geometric Bounds");
  myDialog.myGeometricBoundsRadioButton.value = true;
  myDialog.myVisibleBoundsRadioButton = add('radiobutton', undefined, "Visible Bounds");
  with(add('group')){
  orientation = 'row';
  alignChildren = 'center';
  spacing = 2;
  with(add('group')){
  alignChildren = 'right';
  var myXOffsetLabel = add('statictext', undefined, "Horizontal Offset:");
  var myYOffsetLabel = add('statictext', undefined, "Vertical Offset:");
  with(add('group')){
  myDialog.myXOffsetField = add('edittext', undefined, "0", {enterKeySignalsOnChange:false});
  myDialog.myXOffsetField.characters = 7;
  myDialog.myXOffsetField.justify = "right";
  myXOffsetField.onChange = function(){
  if(myValidateNumber(myXOffsetField.text)==false){
  alert("Invalid numeric entry!");
  myDialog.myXOffsetField.text = "0";
  myDialog.myYOffsetField = add('edittext', undefined, "0");
  myDialog.myYOffsetField.justify = "right";
  myDialog.myYOffsetField.characters = 7;
  myYOffsetField.onChange = function(){
  if(myValidateNumber(myYOffsetField.text)==false){
  myDialog.myYOffsetField.text = "0";
  with(add('group')){
  add('statictext', undefined, "points");
  with(add('group')){
  alignment = 'right';
  myDialog.myCloseButton = add('button', undefined, "Close", {name:'cancel'});
  myDialog.myCloseButton.onClick = function(){myDialog.close()};
  myDialog.myOKButton = add('button', undefined, "OK", {name:'ok'});
  var myReturn = myDialog.show();
  with(myDialog){
  var myTop = myTopCheckbox.value;
  var myLeft = myLeftCheckbox.value;
  var myBottom = myBottomCheckbox.value;
  var myRight = myRightCheckbox.value;
  var myXCenter = myXCenterCheckbox.value;
  var myYCenter = myYCenterCheckbox.value;
  var myXPoint = myXPointCheckbox.value;
  var myYPoint = myYPointCheckbox.value;
  var myXOffset = parseFloat(myXOffsetField.text);
  var myYOffset = parseFloat(myYOffsetField.text);
  if(myGeometricBoundsRadioButton.value == true){
  myBasedOn = 0;
  else{
  myBasedOn = 1;
  if(myEachObjectRadioButton.value == true){
  myRange = 0;
  else{
  myRange = 1;
  myDialog.close();
  else{
  else{
  myDialog.close();
function myAddGuides(myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myRange, myBasedOn, myXOffset, myYOffset, myXPoint, myYPoint, myObjectList){
  var myLayer, myCounter;
  var myOldRulerOrigin = app.activeDocument.viewPreferences.rulerOrigin;
  app.activeDocument.viewPreferences.rulerOrigin = RulerOrigin.spineOrigin;
  //Create a layer to hold the printers marks (if it does not already exist).
  myLayer = app.activeDocument.layers.item("Guides");
  try{
  myLayerName = myLayer.name;
  catch (myError){
  myLayer = app.activeDocument.layers.add({name:"Guides"});
  //Process the objects in the selection.
  for(myCounter = 0; myCounter < myObjectList.length; myCounter ++){
  var myObject = myObjectList[myCounter];
  if (myBasedOn == 0){
  myBounds = myObject.geometricBounds;
  else{
  myBounds = myObject.visibleBounds;
  //Draw guides at path point locations, if necessary.
  if ((myXPoint == true)||(myYPoint == true)){
  myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint);
  //Set up some initial bounding box values.
  if ((myRange != 0)&&(myCounter==0)){
  myX1 = myBounds[1];
  myY1 = myBounds[0];
  myX2 = myBounds[3];
  myY2 = myBounds[2];
  if(myRange == 0){
  myDrawGuides (myBounds[1], myBounds[0], myBounds[3], myBounds[2], myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
  else{
  //Compare the bounds values to the stored bounds.
  //If a given bounds value is less than (for x1 and y1) or
  //greater than (for x2 and y2) the stored value,
  //then replace the stored value with the bounds value.
  if (myBounds[0] < myY1){
  myY1 = myBounds[0];
  if (myBounds[1] < myX1){
  myX1 = myBounds[1];
  if (myBounds[2] > myY2){
  myY2 = myBounds[2];
  if (myBounds[3] > myX2){
  myX2 = myBounds[3];
  if(myRange != 0){
  myDrawGuides (myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset);
  app.activeDocument.viewPreferences.rulerOrigin = myOldRulerOrigin;
function myDrawGuidesAtPathPoints(myObject, myXPoint, myYPoint){
  for(var myPathCounter = 0; myPathCounter < myObject.paths.length; myPathCounter++){
  for(var myPointCounter = 0; myPointCounter < myObject.paths.item(myPathCounter).pathPoints.length; myPointCounter ++){
  if(myXPoint==true){
  myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[0], 1);
  if(myYPoint==true){
  myDrawGuide(myObject.paths.item(myPathCounter).pathPoints.item(myPointCounter).anchor[1], 0);
function myDrawGuides(myX1, myY1, myX2, myY2, myTop, myLeft, myBottom, myRight, myXCenter, myYCenter, myLayer, myXOffset, myYOffset){
  if (myTop == true){
  myDrawGuide(myY1 - myYOffset, 0);
  if (myLeft == true){
  myDrawGuide(myX1 - myXOffset, 1);
  if (myBottom == true){
  myDrawGuide(myY2 + myYOffset, 0);
  if (myRight == true){
  myDrawGuide(myX2 + myXOffset, 1);
  if (myXCenter == true){
  myDrawGuide(myX1+((myX2-myX1)/2), 1);
  if (myYCenter == true){
  myDrawGuide(myY1+((myY2-myY1)/2), 0);
function myDrawGuide(myGuideLocation, myGuideOrientation){
  var myLayer = app.activeDocument.layers.item("Guides");
  with(app.activeWindow.activeSpread){
  if(myGuideOrientation == 0){
  with (guides.add(myLayer, undefined, undefined)){
  orientation=HorizontalOrVertical.horizontal;
  location=myGuideLocation;
  else{
  orientation=HorizontalOrVertical.vertical;
function  myValidateNumber(myString){
  var myRegExp  =  /(^-?\d\d*\.\d*$)|(^-?\d\d*$)|(^-?\.\d\d*$)/;
  return myRegExp.test(myString);
Advance Thanks,
K
Scripting
575
People's Champ ,
Wouldn't it just be a call to the myAddGuides function with your own set of arguments ?
Guide ,
Hi Loic,
Yes I tried and failed. Not sure I did correct or wrong. Is it something controlled by onClick function?
K
Guide ,
Apr 27, 2017 Apr 27, 2017
It is worked with the following changes
to
myDialog.show();
//~ if (myReturn == true){
