Hello every one. I am laying out a brochure in ID CC on a Mac. I have an anchored image with text. For some reason the type wants to skip to the next line early. That is to say even though there plenty of room for text on that line it wants to drop it to the next line. I am attaching an image of the issue and images of the text wrap panel and the text frame options. As you can see there is more then enough room for the word "Hospital" but for some reason it wants to group "Hospital in Chicago" all as one block. Any ideas why? There aren't any other objects with text wrap that could be interfering so I am confused.
Try turning off (in your paragraph style) under Indents and Spacing > find the checkbox for Balance Ragged Lines. Does that influence it?
Hmmmm. Forgive my ignorance is that left justify and align to grid?
Yes!
That was the solution. Thanks!
That was it! Thanks. That was very frustrating.
If you want to keep specific word together use either a nonbreaking space or keep paragraph style. Or use the balanced lines command in paragraph styles or as script.
Your answer was very useful. I'll have to look up non breaking spaces and keep paragraph style. Im a bit unfamiliar with those options.
Next time I answer in Japanese!
