2
What is shortcut for Fit up to 100%?
Nov 17, 2008 Nov 17, 2008
Hi
Is it possible to create shortcut for Fit up to 100% command in After Effect?
Thanks for any help.
How to
69.7K
Explorer , Apr 27, 2017 Apr 27, 2017
Excuse me.  Let me clarify.
Increase the content in your composition window to 100%: /
*Fit* the content in your composition window to 100%: Shift+/
Are you referring to scaling a layer to fit the dimensions of a composition, or are you referring to zooming in a view so that the composition fits the size of the viewer?
Shortcuts for scaling a layer to fit the composition are in the "Shortcuts: modifying layer properties" section of After Effects Help on the Web.
Shortcuts for zooming in a view so that the composition fits in the viewer are in the "Shortcuts: views" section of After Effects Help on the Web.
I found both of these with this Community Help search .
Ctrl+Alt+F - Fit All
Ctrl+Alt+Shift+G - Fit Vertical
Ctrl+Alt+Shift+H - Fit Horizontal
Mylenium
Thanks for the reply, I found it in "Shortcuts: views" . thanks
Participant ,
You need to be very careful with the CTRL + Alt + F command. You can easily end up with distorted images. Any scaling should have the same X and Y values.
If I'm filling a frame with an image I always use Ctrl?Cmnd + Alt/Option + H.
Mar 08, 2016 Mar 08, 2016
fit to 100% for CC suit 2014 is /
That was the right answer for me!  Thanks, rizwanahmed.rizvi!
Feb 11, 2017 Feb 11, 2017
macosx Alt+/
Just to clarify the fit shortcuts that Mylenium posted fit a layer to a composition, the / and Alt+/ (mac) fit a comp to the comp panel.
on Mac, to make your comp viewer return to 100% within its given window size (as opposed to "full screen") just press the "/" key, regardless of what window you are clicked IN to.
Contributor ,
Nov 08, 2023 Nov 08, 2023
What is the difference between "Fit" and "Fit up to 100% (200%)"? They seem to work identically, don't they?
