Seams showing
Apr 22, 2017 Apr 22, 2017
Hello, I was wondering if anyone else had this issue.
I am doing rigging test for my character, I have an animation for the arm, and for some reason, there is a soft black outline around the piece that is animated.
I tried fixing by adding blue mass behind the arm but it changes nothing.
Here is a picture that shows what I mean
Here is the puppet in illustrator, the lines should not be there. Plus the piece is larger than where it seems to cut, it's almost as if it was transparent in CH
Thanks in advance
789
Adobe Employee ,
Apr 25, 2017 Apr 25, 2017
That does seem unexpected. Is that in the Puppet panel, Scene panel, or both?
The torso layer is appearing below the arm layer in the Puppet panel?
If you'd like to share a link to the artwork file (via Dropbox, Google Drive, etc.), via direct message or here, I can investigate what might be going on.
Thanks.
Adobe Employee ,
Apr 27, 2017 Apr 27, 2017
If you're still encountering the issue, could you send a shared link to the artwork file so that we can diagnose the issue? Thanks.
Sorry for the delay. It seems I was able to resolve it. Turns out I had accidentally cut my upper arm into more than on part. A quick pathfinder merge solved the issue. Still a little odd but I'm guessing it was because of the slight movement in the piece.  Thanks for responding.
Adobe Employee ,
The seam is due to the adjacent edges of paths being near pixel boundaries. If you switch AI to use Pixel Preview mode, you should be able to see fractional alpha edges. They don't sum together, they screen (e.g., 50% over 50% is 75%, not 100%). Creating some overlap or merging as you did is the solution here.
BTW, After Effects has a special Alpha Add blending mode for this, as described here: https://www.provideocoalition.com/after-effects-hidden-gems-weekly-alpha-add-mode/
