Remove outline from image?
Apr 27, 2017 Apr 27, 2017
I have this image that has a white background. If i try to remove the background or fill with black, I get this ugly grey/white outline.
Is there a way to remove it?
9.6K
Adobe
Absolutely, but can you paste the original with white background please?
That is such a simple image that while you could attempt to remove the lines, It would be much easier and cleaner to just use the pen tool and redraw the shapes.
I was going to suggest Blend If, but moving the slider far enough to fully remove the fringe, starts eating into the tan colour, so that's a no go.
So select the white with the Magic wand with a tolerance of about 50.
Invert the selection (Shift Ctrl i) and copy to a new layer.  This removes nearly all the white background, but leaves a slight fringe
So go Layer > Matting > Defringe chose a 1 pixel radius
Job done
Advocate ,
Hi Trevor
I'm assuming you erased the white background with an eraser tool. If that's the case you can "defringe" the edge to clear way the extra pixels that were leftover. Go to Layer>Matting>Defringe. You should only need a pixel setting of one for this.
Good luck.
Sep 23, 2019 Sep 23, 2019
Hi: Am trying to remove a fine black outline from around my image, put there by the printer of the image, which was returned to me in jpeg form. Layer/Matting/Defringe doesn't work for this. Can you suggest anything else? Thanks. Lorraine
If you don't want to redraw, the other option that i use a lot is to use the magic wand tool at 100% select all the black, and ctrl/cmd-J to make a new layer. Lock the transparency of the layer, and refill with the black, sampled from the original. Do the same for the orange.
