it happens with every brush, if i do a line and draw on top of it , it inverts the color, please help i tried everything.
Check the blend mode in the options bar
Check the layer blend mode.
Is it the normal brush or the art brush?
the blend modes are normal and everything ok if i use the pencil tool
In addition check the brush mode is set to normal and the layer modes are set to normal on both the layer you are painting on and the layer above or below.
well the layer modes are normal but how to check the burshes mode
Like so:
oh yea, it was set to "diffrence" now i changed it normal and everything is ok, Thanks!
Ok then please mark Trevor.Dennis​ answer either helpful or correct as he was the one who suggested you look at all of these things and responded first.
This helps others when they run a search via google etc as it indexes it.
Thank you for this. I just had the SAME issue. Saved me a ton of hours trying to figure it out. Thank you!
