After I use the defringe in Photoshop I keep getting this effect, how do I stop this
Are you viewing this at 100% zoom ratio? It's the only way to fully trust what you see on the screen.
How did you apply defringe? It is usually used on a layer that contains an object with transparent background like this
Are you adding the sky? If yes, is it to the same layer as the rock? If yes, that's not a good way to do it. You should copy the rock to a new layer, and place the new sky behind it. That avoids the sort of fringing you get from antialiasing where the two edges meet.
Apologies if you knew that.
I am selecting the temple by choosing , select, color range, select the sky, inverse, modify, feather, . Then I drag the selected image to the sky photo its when I try to defringe after this I get that effect
