I have LR 6 stand alone on desktop and PC. Cannot use CC as I need laptop in a very remote area I often work in which has no internet connection and often limited telephone landline and/or mobile.
Recently got this error message on laptop, similar message on PC has now been fixed, but I cannot find a solution.
Error message:
"Procedure entry point not found AgTtransitCargo-pushTransitCargo could not be located in Dynamic link libraryAgKernal.dll."
I also have PS5 download on same laptop and that is still OK.
I would really appreciate any help with this as I am starting to go around in circles.
Hi FrankFitzpatrick,
You can try reset the Lightroom preferences back to default, refer: Preference file and other file locations | Lightroom CC and 6​
If the above solution doesn't solve your problem then you can uninstall the Lightroom, restart the machine and reinstall it from the creative cloud desktop app.
Mohit
Mohit
I had the same problem, and so I followed your recommendation:
But after uninstalling and reinstlling LR 6.6 (standalone version) and downloading and running the Update ZIP file, I still get the same error message: "procedure entry point ucvtbase.terminate...." not found.
As a consequence, I cannot use LR at all, neither the previous version 6.6 nor the most recent version (6.10?) which U would have needed to edit files from Olympus EM1-II.
So I am totally frustrated.
What should I do?
FWS
Thanks, but unfortunately the suggestion did not work. The error message reappeared after installing the Windows vc_redist.x64.exe
I thend deinstalled LR, restarted the computer and then re-installed LR 6 (the copy that I had bought at the end of last year). It worked as it had done before the upgrade. But when I then installed the Update Zip to LR 6.10 (which I need for the Oly EM1-II), I again saw the error message and could not start LR.
Any other suggestion?
