Hello, need help
I have a network of 3 quad core macs with 16gb memory and ssd's all with the Adobe After Effects render engine running looking at a maped network accessible drive then to a watch folder. They all recognize if a project is placed in it as I get an error meessage once I do on each computers engine saying "Render control file not valid fo (my filename)" . I have the latest update of after effects "14.2.0.198" and all computers nodes are the same. The server or main computer where the watch folder is has a simple comp with no effects others then text movement key framed in a 20 minitue journey across the screen to make sure that the comp, plugins or any thing with the comp would not be causing me the error. As all plug ins must be network wide.
I select a tiff image sequence
turn on multi Machien rendering
and. Pick a out put folder
then get all dependances and export it into the watch folder
and always get that errror message
does any one else have this issue???
or have a working mac render farm on cc 2017 environment?
please help
Hi 7UpSpecial,
See if this discussion assists you: Re: Render control file not valid for" project.aep -- Please Help!
Kevin
