Locked
Text boxes overlapping instead of pushing content down
Apr 28, 2017 Apr 28, 2017
I've been having a lot of issues with this. Sometimes it works and sometimes it doesn't. I create two text boxes one on top one on the bottom. I figure that when you start filling up the text box on the top the text box below should automatically be pushed down the page. The frustrating thing is that usually when I set it up initially it works but then when I format the text box doesn't push the box down anymore it just overlaps it... It really has been making no sense to me. I've searched but can't find an answer, is there an easy fix or is it a bug?
2.9K
LEGEND , Apr 28, 2017 Apr 28, 2017
You pinned the text boxes to the center of the canvas, ...
I unpinned them, set them underneath each other in every breakpoint
and there you go.
Of course you have to place them correctly, then it should work as expected.
Pinning and pushing each other down is not supported. This happens, BTW, to accordions as well, if you don`t want to
overlapp content below. Anything has to be unpinned which should push something to any place.
Hope this helps to keep on working before sunday afternoon .
This is normally a quite simple thing. The only thing we need to help efficiently:
Create a new site with only one page and only a few elements, which demonstrate your issue clearly. (This is necessary, because it saves download- and analysing-time). Upload this .muse file (without assets) to Dropbox or a similar file sharing service and provide the download link here. Then we can have a closer look.
Thus, time consuming „question and answer“ games or pure guessing can be considerably reduced.
Thank you, here is the link..
https://www.dropbox.com/pri/get/text%20box%20sample.muse?_subject_uid=12729754&w=AADAXBRtdbtYiKpunBOz9t1ebKnaK2BTAVRiFLdhN9OyzA
The link doesn’t work! You have to give us a public link!
Sorry here you go...
https://www.dropbox.com/s/i7ibcmkz9whyq90/text%20box%20sample.muse?dl=0
Set the two text boxes in every breakpoint to "Resize: Responsive Width" (small menu in the upper cotrol strip) and check. that the text boxes don’t overlap in any breakpoint.
So I did everything you said then I entered text in the upper text box in the 1200 breakpoint and the box just overlapped into the box beneath.. try if for yourself..
https://www.dropbox.com/s/1cizwrgi5848uxw/text%20box%20sample%202.muse?dl=0
I'll try sunday afternoon!
and there you go.
Apr 29, 2017 Apr 29, 2017
Great!!! thank you very much, that was driving me mad!!!… your help was much appreciated..
Welcome bobsybob all time. I had good teachers - he, Günter Heißenbüttel​ was one of them.
Uwe
I'm having a very similar issue.. This first image is before I change the browser width...
And after a small change to the browser width...
When the "garages and carports" header changes height everything moves down including the grey box behind it. But the "extensions, orangeries.." header doesn't move...
This is driving me mental! Any suggestions welcome. Nothing to do with pinning as the box below "garages..." header is pinned left and works fine..
Thanks everybody
Hi mattb76842097​, your problem looks quite different. But for checking mor properly we would need a .muse.
Reduce your issue to one page with these two elements and we can have a look at it.
The issue for: bobsybob​ should be solved for mow, I guess.
Cheerio
Uwe
