I would like to be able to hit the z button on my computer and get the zoom tool, as I was able to do when I was using Photoshop7.
Scenario: I am using the lasso tool. I want to zoom so I hit z and the tool switches to zoom, and I draw a box around the area I want to zoom into. I get no zoom and after a few seconds a lasso selection shows up in the area instead. I look and the tool has reverted to lasso. I have discovered that I need to hit z twice although this does not work 100% of the time. Even worse- sometimes I'm using the erase tool and I accidentally erase stuff when the tool switches back to erase even though I pressed z. I will see the the tool has switched to zoom as it should when pressing z, I will make a box around where I want to zoom and then I see stuff get deleted because the stupid thing switches back to erase!
This really screws up my pace while I'm working. Please tell me there is a solution for this...
Hi Patricia
I think you are just holding down too long on the z key. Photoshop will switch tools if you quickly tap the z key. If you hold down on the z key it will temporarily switch tools (for as long as you are holding the key) and when you let go it switches back to the previously selected tool. So try a quick tap to get the default behavior that you want.
Let us know if that helps
Michael
Which version of Photoshop? Which operating system?
Hi Patricia
Michael
