Hi i am designing my cv in the photoshop.I am having an issue with masks.
When I save the file to the pdf and open it looks all fine but when I open the same file on my phone it shows thin white lines around the layer masks and it does the same when I upload to my potofolio website.When I flatten the file then those lines disappear.But i dont realy want to flatten it as it effects the visibility of the file.
Anyone know how can i remove these lines.
Any help will be much appreciated.
(These white lines only appear on smaller screens.)
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, ā¦) visible of both an affected Layer on the Canvas and one of the Layer Masks?
The correction is as easy as erasing the edge using the ERASER tool on the background OR just painting the edge black on the layer mask itself.
I don't think it's quite as simple as that.
This is probably a display scaling artifact from not showing the file at 100%. The same thing is seen in some other circumstances, like e.g. mask edges in panos. It will disappear at 100% view. It will also disappear when flattening (which will obviously rasterize the text).
You should really not use Photoshop for this type of thing. You should make it in InDesign and output a screen PDF from there.
I did try this but unfortunately it doesn't work.
Thanks anyway
Thanks for your time
I did try both these things but they didn't work
I also tried matting but that doesn't work either
Did you try saving a PDF X4?
yes I did try this as well but white lines still there.
thanks anyway
