What in the world is causing correctly exposed images to be covered in bright neon colored lines?
Thanks for help. I think I had a bad card download on an old card reader. I re-downloaded them w a different card reader and they now look fine in Lightroom. Whew!
It would help if you showed us a screen capture.
One common cause of this is a hardware malfunction that has corrupted the image. You should try importing the photos again using different hardware to see if you can isolate the cause of the problem.
Try disabling the Graphics Processor
Lightroom Preferences > Performance, uncheck Use Graphics Processor
