[Moderator moved from The Lounge to InDesign.]
Text wrap should move text (not text frames) out of the way of the object that you assigned it to. I see an elliptical frame in your screen shot, but I don't see text wrap boundaries on it. I think a little more information will be needed to give you the answer you are are looking for.
Can you please share two more screen shots of the entire screen, with the text wrap panel open?
In the first one, show what the page looks like before you enable text wrap, and in the second one, show what the page looks like after you select the wrap object and turn it on.
It looks like your text boxes are not disappearing -- the type inside some of the text boxes is disappearing -- like on the first and fourth text box. On those boxes, the box is not wide enough to display any characters, and there may be keep options or hyphenation settings preventing any characters from showing.
Resetting the "keep options" to keep lines together enabled the text to show through properly! Thank you for that! Unfortunately, now none of the text is wrapping...back to the drawing board! Thank you!
Would be helpful to see a screen capture of what it looks like now.
Still doing it, ugh.
Never had this problem before
By any chance are text boxes set to ignore text wrap?
Another possibility, in Preferences, is text wrap only affects text beneath turned on?
My advice:
Carolyn: yours is now working as I'd expect it to.
Off:
On. The text gets out of the way of the ellipse, and text frames that are fully covered are empty. (This is different from your first screen shot.)
Now the question is—what do you want from this wrap? Making the frames bigger, and moving the ones that are under the ellipse out the the side would improve the look.
Although you aren't asking, it is considered best practices to put all of this text into one frame instead of all separate frames.
If all of this text is in one frame, and if the frame is wide enough, it will solve your text wrap issue with the oval.
