I'm trying to pass the files and folders to one of our
developers so that he can begin doing/ testing what he has to do. I
have added his network information to the last screen in the
WebHelp(Primary Layout). I generate the project after checking his
employee folder location. I check his folder and the project isn't
there. What am I doing wrong?
Yes, all publishing does is move your WebHelp output to the
location you selected. You can generate and publish as many times
as you need. Unless you select "Republish all" on the last page of
the WebHelp dialog, only the files that have changed will be
published after the first time that you publish the output.
And then I can go back and continue working on the project? I
was afraid if I hit publish I was kaput. As long as that isn't the
case I'll breathe a little easier.
