Create popup warning that autocloses
Apr 28, 2017 Apr 28, 2017
Hi
I'm trying to pop up a warning dialog for 2 seconds then have it close.
The following code works:
var w = new Window ("palette","test", [200, 200, 680, 325], {resizeable: false});
w.show();
alert("hi");
w.close();
but obviously doesn't autoclose
w.show();
//delay(2);
$.sleep(2000);
w.close();
function delay(prmSec){
  prmSec *= 1000;
  var eDate = null;
  var eMsec = 0;
  var sDate = new Date();
  var sMsec = sDate.getTime();
  do {
  eDate = new Date();
  eMsec = eDate.getTime();
  } while ((eMsec-sMsec)<prmSec);
using either delay or sleep the palette only shows up occasionally (every third run of the script...)
1) any idea WHY it doesn't show up reliably?
2) is there a better way to make a popup?
thanks
Scripting
1.3K
Guide ,
If i tested in Extendscript then it work good..
I know. But in Indesign it doesn't.
(I'm using CC2015 on a mac in case that's part of the problem)
did you run it from the ESTK addressing InDesign?
Do not run it from the ESTK.
Run it by double-click from InDesign's Scripts panel.
Another example that is working for me with my German InDesign CC 2017.1 on German Mac OSX 10.10.5
( started from the Scripts panel… )
var dlog = new Window("palette");
dlog.size = [320,100];
dlog.add("statictext", undefined , "We are closing in 2 seconds.");
dlog.show();
// Have a nap:
$.sleep(2000);
// Closing the dialog:
dlog.close();
Uwe
I was running it from InDesign.
Your code doesn't work either... it executes -- but the palette doesn't show up.
If I put an alert before the sleep it shows up immediately. I'm suspecting some redraw issue with ID
adding a .update() before the sleep solves the problem...
Reading the discussion about progress bars it seems it's an OSx/ID bug
Apr 30, 2017 Apr 30, 2017
Hi Akiva,
just tested with InDesign CC 2015.4.1 and CS6 8.1.0 as well.
My code is running ok. The "palette" type of Window is showing up and vanishes after the $.sleep() period.
For me the update() is not necessary but I guess it would not hurt…
What is your OSX version?
Mine is 10.10.5.
Maybe there are other things involved that makes it necessary to do an update() for you?
Uwe
Hi Uwe
I'm running 10.12.4 -- on an airMac so I don't have a GPU (according to ID) with CC2015
CS6 works fine without the update()
I've noticed other graphic glitches with the last update to CC2015 -- text vanishes on the screen, and I have to force a redraw to see it again)
Guide ,
May 03, 2017 May 03, 2017
Thanks for reporting these issues.
So I've just added the update() trick in IdExtenso's messaging API.
IdExtenso/$$.messaging.jsxinc at master · indiscripts/IdExtenso · GitHub
By the way, does anyone actually understand the purpose of Window.update()? I mean, the way it should theoretically work and the context from which it should theoretically be invoked. Although documented, this method remains very obscure to me.
Marc
May 25, 2023 May 25, 2023
@akiva_atwood said: "I've noticed other graphic glitches with the last update to CC2015 -- text vanishes on the screen, and I have to force a redraw to see it again)"
Hi @akiva_atwood ,
just tested the "palette" type of window without using update() on Windows 10.
Ran the script from InDesign's Scripts panel. No issue with my German InDesign CS6 version 8.1.0 or InDesign 2023 version 18.1.0.51.
#targetengine autoCloseAlert
var sleepPeriodInSeconds = 2;
var sleepPeriodAsString = " " + sleepPeriodInSeconds + " ";
dlog.add("statictext", undefined , "We are closing in"+ sleepPeriodAsString +"seconds.");
dlog.show();
// Is that necessary? :
//~ dlog.update();
// Perhaps on some versions of macOS together with some specific versions of InDesign?
// Have a nap:
$.sleep(sleepPeriodInSeconds * 1000);
dlog.close();
Uwe Laubender
( Adobe Community Expert )
