alpenman69 wrote:
> I would like to strip (or replace) all non utf-8
characters from a string (for example a form-textfield). What is
the most simple way to achieve that?
no such thing as non-utf8 chars. what exactly are you trying
to do?
alpenman69 wrote:
> I would try to clean the string before sending it to a
database (sql server)
ok, but strip it of what? everthing's in unicode. utf-8's a
stingy multi-byte
encoding (ie it expands the bytes needed to represent a char
only if needed) so
what exactly are you trying to get rid of?
when you paste a text (for example from MS Word) into a
formfield and write the string to sql server database, you will see
that some characters are replaced in the database as a symbol
(square).
a square means either there's a slight encoding issue or more
likely the font you chose to display these doesn't contain that
glyph.
if your table is using one of "N" datatypes to hold your
unicode text and you're using the JDBC driver instead (labeled as
ms sql server) of the ODBC one then it's most likely a simple font
issue.
got a public page i can see that shows this issue?
