Hi there,
I noticed now for some time that the 'fast export to PNG' does not always work ...
Eg
I open several images in PS ...
I export one via the 'fast export to PNG' option .. that works fine ..
I then switch to a different document and perform the export ... then sometimes it simply doesn't do anything ... no reaction, nothing saved on disk ...
It also happens with only 1 open document ... several exports work and then suddently it doesn't do anything anymore ( and I check if the already existing PNG is updated or created ).
The only way to 'remedy' is then to close the document(s) and reopen them ... it then works again ...
Steven
Here is some system info:
Versie Adobe Photoshop: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877 x64
Versie: 10 of hoger
Systeemarchitectuur: Intel CPU-familie:6, Model:14, Stepping:3 met MMX, SSE-integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Aantal fysieke processors: 4
Aantal logische processors: 8
Snelheid processor: 3408 MHz
Ingebouwd geheugen: 65496 MB
Hi Steven,
Thank you for providing the relevant information about the issue. As "Quick export as PNG" feature is not working for you, are you getting any errors?
Which operating system are you using: Windows or Mac?
Sahil
Hi Sahil,
Thank you for your reaction ...
When the export is not working I am not getting any errors, notifications or warnings ... it simply doesn't do anything it seems ..
I am on windows 10.
Kind Regards,
Steven
