I used the clone stamp and pencil tool before it went wrong.
Here are some print screens about it. On the second full print screen I used the clone stamp and thats what happened. On the last full print screen the blue lines are visible. It gets worse the more I paint. When I use a layer mask to delete it it goes crazy. Some areas get unpaintable completely in little square shapes.
I would greatly appreciate some help !
Nóri
Did it start working after unchecking the GPU? If Yes, then please check this link and see if your GPU is compatible with Photoshop, if it is compatible then you need to update the GPU drivers from manufacturers websites such as Nvidia and AMD then recheck Use graphics processor in Photoshop. Photoshop graphics processor (GPU) card FAQ
Hi Nóri,
As your brush strokes are pixelated could you try changing the bit mode of your image.
Image > Mode > choose higher Bit/Channel
Sahil
Than you for the quick answer. Though I have tried it and it does not help.
I am guessing something is up with the layers not the tools because when I use the layer mask to mask something off the photo,
it is a complete disaster. Or some tool setup that affects the whole layer.
What happens when you uncheck "Use Graphics Processor Under Photoshop > Preferences > Performance then relaunch Photoshop?
I do not want to be too quick to judge but it seems like it is working again !!!!!
Thanks a lot !!!!
Do you have an idea what might have gone wrong ?
I was just practising the pen and stamp tools.
Ah thank you. Yes it started working after unchecking and relaunching.
I'm glad you got it working. Feel free to reach out to us for any future queries.
