Hello everyone,
As part of my work I get sent exported PDFs created using InDesign. I should point out that I do not have InDesign myself so I'll have to pass any answers here on to my colleagues.
I am currently working on a book and the pictures have not been approved yet (or are confidential). In the PDF I then get a grey box with a black cross running through it as a placeholder.
Problem is now that this eats up the black ink in my printer at an alarming rate (even with the quality right down). The book is about 200 pages and there are LOTS of grey areas in it.
So my question is, is it possible to have a white background to the pictures instead of grey?
Many thanks in advance
Mark
Go to Tools > Content > Edit Object...
Click a gray-filled frame to select it, then either tap the Delete key or right-click and choose Delete.
I doubt you can solve this problem with a print setting. Other options:
Hello John, thanks for your answer.
1. I'm sure if I ask them they will have no problem with it. How do you go about doing this?
2. I use Acrobat Pro X. I can delete pages (which helps) but was not aware of the possibility of deleting elements in the PDF. Do let me know if this is not too much trouble.
Many thanks.
Mark
