Hello. I'm designer and I have one hand only and I can't use a hotkeys while I'm using a mouse to draw smooth curve and a good selection. So what should i do?? Note I have used a sticky keys before but it doesn't fit for me.
My mail is xxxxxxx@xxx [email address removed by moderator—this is a public forum]
As far as I can tell, the issue is about how do deal with accessibility issues in Windows 7. I'm not an accessibility expert, but I know that the Macintosh (which I use) have a large number of accessibility features for different kind of accessibility issues. I know nothing of what Windows 7 has to offer.
You might need to ask in a Microsoft forum unless someone who comes here has the same combination of issues.
Using which Adobe software? Which operating system?
you have not answer my question yet and 'm waiting your reply
My operating system is Windows 7 32bit
And I use photoshop. Illustrator and InDesign
I used Google to find this from Microsoft. Scroll down to find Windows 7. It looks like there is more with each version of Windows. I'm on a Mac and can't test these.
https://support.microsoft.com/en-us/help/13810/windows-keyboard-shortcuts-accessibility
and also this:
Windows 7 and Windows 8 – Using your keyboard one handed | My Computer My Way
The note at the bottom of the page says this:
Note: If this does not work it could be because your computer settings cannot be changed due to local IT policies – contact your local IT support for further help.
Are you using this at home or at work? If you are at work, contact your IT department.
Hi Mohamed,
Apart from the suggestions above, I would also like to suggest you to try the "Touch" workspace of InDesign. It definitely does not have all the options as a normal workspace, however it might be an easy alternative for you.
Om
