Script to get the image height and width
Apr 29, 2017 Apr 29, 2017
I need to know the size (dimensions) of images placed in an InDesign 5.5 document.
I have made the following script by combining different code. It gets the metadata OK, but the witdh and height are empty. Am I using getProperty wrong?
// Refr
// https://forums.adobe.com/thread/288764
// https://forums.adobe.com/thread/2288546
    var scriptName = "Get description from selected link",
    doc;
    PreCheck();
      //exif:PixelXDimension   tiff:ImageWidth
    //===================================== FUNCTIONS ======================================
    function Main(image) {
        var link = image.itemLink,
        metadata = link.linkXmp,
        description = metadata.description,
        format = metadata.format,
        author = metadata.author,
        modificationDate= metadata.modificationDate,
        creator = metadata.creator,
        myLinkWidth = metadata.getProperty("http://ns.adobe.com/tiff/1.0/", "tiff:ImageWidth"),
        myLinkLength = metadata.getProperty("http://ns.adobe.com/tiff/1.0/", "tiff:ImageLength"),
        Width = metadata.getProperty("http://ns.adobe.com/exif/1.0/", "exif:PixelXDimension"),
        Height = metadata.getProperty("http://ns.adobe.com/exif/1.0/", "exif:PixelYDimension");
       alert("Description is: '" + description + "'\nFormat: " + format + "\nAuthor: " + author + "\nDate modified: " + modificationDate + "\nCreator: " + creator, scriptName, false);
        alert("Pixel dimentions of image:\nWidth: " + myLinkWidth + Width + " pixels\nHeight: " + myLinkLength + Height +" pixels");
    function PreCheck() {
        var image;
        if (app.documents.length == 0) ErrorExit("Please open a document and try again.", true);
        doc = app.activeDocument;
        if (doc.converted) ErrorExit("The current document has been modified by being converted from older version of InDesign. Please save the document and try again.", true);
        if (!doc.saved) ErrorExit("The current document has not been saved since it was created. Please save the document and try again.", true);
        if (app.selection.length == 0 || app.selection.length > 1) ErrorExit("One image should be selected.", true);
        if (app.selection[0].constructor.name == "Image") { // image selected with white arrow
            image = app.selection[0];
        else if (app.selection[0].images.length > 0) { // container selected with black arrow
            image = app.selection[0].images[0];
        else {
            ErrorExit("No image in the selection.", true);
        Main(image);
    function ErrorExit(error, icon) {
        alert(error, scriptName, icon);
        exit();
I'll explain why I'm doing this:
I'm making a magazine and the photos we get are in all different sizes and quality. In a layer called "picName" I have text frames on top of images with information from Text Variables such as name of file, PPI, actual PPI, dimensions, and scale. I make a pdf of the magazine and while my editor proof reads and edits the document I fix the photos (I cannot use InDesign at same time as she.). I use the information from the picName-layer and an Excel-sheet to determine the right size of the images, and then I edit the images in Photshop.
It would be a lot easier to have the calculation in the pdf itself. What I hope to achive is:
  1. Get the width (W) of the linked image.
  2. Get the PPI (P) of the linked image.
  3. Get the scale (S) of the image in the frame (percent).
  4. Calculate the width the image should have: W * S * 300 / P
  5. Insert the width the image should have in a text frame in the picName-layer on top of the image.
Scripting
8.8K
Explorer , May 01, 2017 May 01, 2017
Sorry, I don't have time to explain, but this code works!
//Refr
//https://indisnip.wordpress.com/2010/09/02/quicktip-insert-text-variable-to-text-frame/
//DESCRIPTION:Label image with its size
// Jongware, 13-Jan-2012
// No Guarantees, Etc.
// https://indesignsecrets.com/topic/script-to-label-selection-with-height-and-width
if (app.selection[0] instanceof Rectangle) //Check if selected object is a graphic frame (I can't find a way to check if it is a linked image
  app.doScript(labelItem, ScriptLangua
Guru ,
Apr 30, 2017 Apr 30, 2017
Try this:
var myLinkWidth = metadata.getProperty("http://ns.adobe.com/tiff/1.0/", "tiff:ImageWidth");
var myLinkLength = metadata.getProperty("http://ns.adobe.com/tiff/1.0/", "tiff:ImageLength");
because the properties are here:
— Kas
Thank you. I now tried this:
var image = app.selection[0].images[0];
var link = image.itemLink;
var metadata = link.linkXmp;
alert("Pixel dimentions of image:\nWidth: " + myLinkWidth + " pixels\nHeight: " + myLinkLength +  " pixels");
But the variables are still empty. It seems like the new code is doing the exact thing as in lines 19 & 20 of the original script.
Could you please test it in your InDesign and see if it works? Thank you!
'metadata' is not a property. Use linkXmp:
app.documents[0].links[0].linkXmp.getProperty("http://ns.adobe.com/tiff/1.0/", "tiff:ImageLength");
But that returns 'undefined' most of the time.
Why not use the image's or its parent's geometricBounds?
Guru ,
Happy May 1st, dear forum! 🙂
It works for me, but not with every image:
For some images metadata is unavailable -- grayed out.
— Kas
//Refr
  app.doScript(labelItem, ScriptLanguage.JAVASCRIPT, app.selection[0], UndoModes.ENTIRE_SCRIPT, "Label Image Size");
} else
  alert ("No valid selection.\nPlease select an image with the black arrow before running this script.");
function labelItem (item)
var myDocument = app.activeDocument;
//Define variables as text-variables from the document
var tvDim = app.activeDocument.textVariables.item("dim");
var tvPPI = app.activeDocument.textVariables.item("PPI");
var tvPPIb = app.activeDocument.textVariables.item("PPI b");
var tvProsent = app.activeDocument.textVariables.item("prosent");
    //Get name of image, without file type
    var mySel = app.selection[0];
    var myImageName = mySel.graphics[0].itemLink.name;
    var myImageName = myImageName.slice(0,-4);
    var myTextFrame = myDocument.textFrames.item(myImageName);
  // Save current selected layer because adding one will make it active!
  activeLayer = app.activeDocument.layoutWindows[0].activeLayer;
  // Make sure the layer "bildenavn" exists
  try {
    app.activeDocument.layers.add({name:"bildenavn", ignoreWrap:true, layerColor: [90,192,90], printable: true});
  } catch (_) { }
  reportLayer = app.activeDocument.layers.item("bildenavn");
  // Make sure the swatch "bildenavn" exists
  try {
    app.activeDocument.colors.add({name:"bildenavn", space:ColorSpace.RGB, colorValue:[90,192,90], colorModel:ColorModel.PROCESS});
  } catch (_) { }
  reportGreen = app.activeDocument.swatches.item("bildenavn");
  // Make sure the paragraph style "bildeinfo" exists
  try {
    app.activeDocument.paragraphStyles.add({name:"bildeinfo", appliedFont:"Kozuka Gothic Pro", pointSize:18, fillColor:[Paper], linecoler:[black], justification: Justification.CENTER_ALIGN});
  } catch (_) { }
  reportStyle = app.activeDocument.paragraphStyles.item("bildeinfo");
  // Make sure measurement units are in mm
  hmmu = app.activeDocument.viewPreferences.horizontalMeasurementUnits;
  vmmu = app.activeDocument.viewPreferences.verticalMeasurementUnits;
  app.activeDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
  app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
  // .. and Smart Quotes is Off
  sqt = app.activeDocument.textPreferences.typographersQuotes;
  app.activeDocument.textPreferences.typographersQuotes = false;
  // Save all of the previous settings to be able to restore them later 🙂
  // fetch width and height for the numbers, left and bottom for the lines
  gb = item.geometricBounds;
  // gb now holds [ top, left, bottom, right ] values -- get shorthand values
  top = gb[0];
  left = gb[1];
  bottom = gb[2];
  right = gb[3];
  width = Math.round(Math.abs(right - left)*1000)/1000;
  height= Math.round(Math.abs(bottom - top)*1000)/1000;
  // Retrieve the current page.
  // Actually, in CS5 and newer, page items have a property for this (parentPage),
  // but I don't have that one near, and it's also nicer to make it work in CS4
  // (and possibly even in older versions).
  pg = item.parent;
  while (1)
    if (pg instanceof InsertionPoint)
      pg = pg.parentTextframes[0];
    if (pg instanceof Document || pg instanceof Spread || pg instanceof Page)
      break;
    pg = pg.parent;
  // Draw text frame #1: Height
  // Put it at the left of the selection, 0.5" wide and 0.2" off the left side
  frh = pg.textFrames.add(reportLayer, {geometricBounds:[ top +10, left +10, top +55, left + 80 ], name: myImageName,
    textFramePreferencestextFramePreferences: {verticalJustification: VerticalJustification.CENTER_ALIGN,
    ignoreWrap: true } });
  // ... and put text into it.
  frh.insertionPoints[0].appliedParagraphStyle = reportStyle;
//Insert these text variables into the image's text frame
myTextFrame.texts[0].textVariableInstances.add({associatedTextVariable:tvDim});
myTextFrame.parentStory.insertionPoints.item(-1).contents = "\rEffektiv PPI: ";
myTextFrame.texts[0].textVariableInstances.add({associatedTextVariable:tvPPI});
myTextFrame.parentStory.insertionPoints.item(-1).contents = "\rBildets PPI: ";
myTextFrame.texts[0].textVariableInstances.add({associatedTextVariable:tvPPIb});
myTextFrame.parentStory.insertionPoints.item(-1).contents = "\rSkala: ";
myTextFrame.texts[0].textVariableInstances.add({associatedTextVariable:tvProsent});
//Make the result of the text variabelts into integer
//var myVarValue = mySel.textVariableInstances.item("File Name").resultText;
var myDim = myDocument.textFrames.item(myImageName).textVariableInstances.item("dim").resultText;
var myPPI = myDocument.textFrames.item(myImageName).textVariableInstances.item("PPI").resultText;
var myPPIb= myDocument.textFrames.item(myImageName).textVariableInstances.item("PPI b").resultText;
var myProsent = myDocument.textFrames.item(myImageName).textVariableInstances.item("prosent").resultText;
var myWidth = myDim.slice(0,4);
var intMyWidth = parseInt(myWidth);
var intPPI = parseInt(myPPI);
var intPPIb = parseInt(myPPIb);
var myProsent = myProsent.slice(0,-1);
var intProsent = parseInt(myProsent);
var newWidth = intMyWidth *  intProsent * 300 / intPPIb / 100;
var newWidth = Math.ceil(newWidth)
//Remove
var myMetadataString = "\nBredde " + intMyWidth + "\nNy bredde " + newWidth;
frh.parentStory.insertionPoints.item(-1).contents  = String(myMetadataString);
  // Restore old layer selection
  app.activeDocument.layoutWindows[0].activeLayer = activeLayer;
  // Restore previous global settings
  app.activeDocument.viewPreferences.horizontalMeasurementUnits = hmmu;
  app.activeDocument.viewPreferences.verticalMeasurementUnits = vmmu;
  app.activeDocument.textPreferences.typographersQuotes = sqt;
Engaged ,
app.documents.item(0).viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
app.documents.item(0).viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
var selected = app.selection[0].images[0];
//~ var link = selected.itemLink;
var h = selected.visibleBounds[2] - selected.visibleBounds[0];
var w = selected.visibleBounds[3] - selected.visibleBounds[1];
alert('height: '+h+'\nwidth: '+w);
Prabu
Design smarter, faster, and bolder with InDesign scripting.
May 02, 2017 May 02, 2017
Hi IngyNorw ,
I did a quick test with the script you posted with reply 4 written by Jongware as it seems.
Glad, that it works for you.
But it did not work with a CC 2017.1 document where just one image was placed.
Tested with InDesign CC 2017.1 on Mac OSX 10.10.5.
You ran the script on InDesign CS 5.5.
It seems that are too many changes with InDesign since the days this script was written.
Uwe
