I've got an error in my code and I don't understand code help?
Guest
May 01, 2017 May 01, 2017
​ADOBE ANIMATE
I'm new to coding and I don't understand it. I'm using AS3 and i'm trying to make a pause and play button in my game so I typed in this code:
yourButton.addEventListener(MouseEvent.CLICK, pauseGame);
function pauseGame(e:MouseEvent):void{
     stage.frameRate = 0;
yourOtherButton.addEventListener(MouseEvent.CLICK, resumeGame);
function resumeGame(e:MouseEvent):void{
     stage.frameRate = 15;
and it's giving me errors:
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 81120: Access of undefined property yourButton.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 541120: Access of undefined property pauseGame.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 51120: Access of undefined property yourOtherButton.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 561120: Access of undefined property resumeGame.
I don't know what this means...
(the part that is in Bold is the code it has a problem with) The full code is:
package{
    import flash.display.MovieClip;
    import flash.events.KeyboardEvent;
    import flash.ui.Keyboard;
    import flash.events.Event; //used for ENTER_FRAME event
  import flash.events.MouseEvent;
    public class Main extends MovieClip{
        //constants
        const gravity:Number = 1.5;            //gravity of the game
        const dist_btw_obstacles:Number = 300; //distance between two obstacles
        const ob_speed:Number = 16;             //speed of the obstacle
        const jump_force:Number = 15;          //force with which it jumps
        //variables
        var player:Player = new Player();
        var lastob:Obstacle = new Obstacle();  //varible to store the last obstacle in the obstacle array
        var obstacles:Array = new Array();     //an array to store all the obstacles
        var yspeed:Number = 0;                 //A variable representing the vertical speed of the bird
        var score:Number = 0;                  //A variable representing the score
        public function Main(){
            init();
        function init():void {
            //initialize all the variables
            player = new Player();
            lastob = new Obstacle();
            obstacles = new Array();
            yspeed = 0;
            score = 0;
            //add player to center of the stage the stage
            player.x = stage.stageWidth/2;
            player.y = stage.stageHeight/2;
            addChild(player);
            //create 3 obstacles ()
            createObstacle();
            createObstacle();
            createObstacle();
            //Add EnterFrame EventListeners (which is called every frame) and KeyBoard EventListeners
            addEventListener(Event.ENTER_FRAME,onEnterFrameHandler);
            stage.addEventListener(KeyboardEvent.KEY_UP, key_up);
        private function key_up(event:KeyboardEvent){
            if(event.keyCode == Keyboard.SPACE){
                //If space is pressed then make the bird
                yspeed = -jump_force;
        function restart(){
            if(contains(player))
                removeChild(player);
                for(var i:int = 0; i < obstacles.length; ++i){
                    if(contains(obstacles) && obstacles != null)
                    removeChild(obstacles);
                    obstacles = null;
                obstacles.slice(0);
                init();
        function onEnterFrameHandler(event:Event){
            //update player
            yspeed += gravity;
            player.y += yspeed;
            //restart if the player touches the ground
            if(player.y + player.height/2 > stage.stageHeight){
                restart();
            //Don't allow the bird to go above the screen
            if(player.y - player.height/2 < 0){
                player.y = player.height/2;
            //update obstacles
            for(var i:int = 0;i<obstacles.length;++i){
                updateObstacle(i);
            //display the score
            scoretxt.text = String(score);
        //This functions update the obstacle
        function updateObstacle(i:int){
            var ob:Obstacle = obstacles;
            if(ob == null)
            return;
            ob.x -= ob_speed;
            if(ob.x < -ob.width){
                //if an obstacle reaches left of the stage then change its position to the back of the last obstacle
                changeObstacle(ob);
            //If the bird hits an obstacle then restart the game
            if(ob.hitTestPoint(player.x + player.width/2,player.y + player.height/2,true)
               || ob.hitTestPoint(player.x + player.width/2,player.y - player.height/2,true)
               || ob.hitTestPoint(player.x - player.width/2,player.y + player.height/2,true)
               || ob.hitTestPoint(player.x - player.width/2,player.y - player.height/2,true)){
                restart();
            //If the bird got through the obstacle without hitting it then increase the score
            if((player.x - player.width/2 > ob.x + ob.width/2) && !ob.covered){
                ++score;
                ob.covered = true;
        //This function changes the position of the obstacle such that it will be the last obstacle and it also randomizes its y position
        function changeObstacle(ob:Obstacle){
            ob.x = lastob.x + dist_btw_obstacles;
            ob.y = 100+Math.random()*(stage.stageHeight-200);
            lastob = ob;
            ob.covered = false;
        //this function creates an obstacle
        function createObstacle(){
            var ob:Obstacle = new Obstacle();
            if(lastob.x == 0)
            ob.x = 800;
            else
            addChild(ob);
            obstacles.push(ob);
            lastob = ob;
Message was edited by: JSM (Discussion successfully moved from The Lounge to Adobe Animate CC - General)
382
try:
package{
        //constants
        //variables
            init();
            yspeed = 0;
            score = 0;
            addChild(player);
            createObstacle();
            createObstacle();
            createObstacle();
        function restart(){
                    obstacles = null;
                obstacles.slice(0);
                init();
            //update player
            yspeed += gravity;
            player.y += yspeed;
                restart();
            //update obstacles
                updateObstacle(i);
            //display the score
            if(ob == null)
            return;
            ob.x -= ob_speed;
                changeObstacle(ob);
                restart();
                ++score;
                ob.covered = true;
            lastob = ob;
            ob.covered = false;
            if(lastob.x == 0)
            ob.x = 800;
            else
            addChild(ob);
            obstacles.push(ob);
            lastob = ob;
Guest
May 02, 2017 May 02, 2017
I tried the code and it got rid of two of the problems in it, but it still has two more problems.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 48, Column 41120: Access of undefined property yourButton.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 49, Column 51120: Access of undefined property yourOtherButton.
then you didn't create those two objects.  i can see they're not created with code so they should be created on frame 1.
Guest
I have created them as buttons and it started to work but now the buttons don't do anything.
what do you mean by, '... it started to work'?
Guest
May 03, 2017 May 03, 2017
The game now works but the buttons don't.
use the trace function to debug.  eg, are your button listener functions called?
Advocate ,
You need to give the buttons instance names.
Guest
I did give them instance names
